Old 07-20-2012, 01:34 PM   #1
hgs_notes
GEARHEAD
hgs_notes's Avatar
Bucket seat under floor brace
I cut out the front floor seat brace from a blazer tub to use for bucket seats. Nice to have if you are installing original style buckets in your truck. I sand blasted it and it's in good shape. Three piece set, middle section and 2 outbord pieces. $175 shipped.
hgs_notes is offline   Reply With Quote
Old 07-20-2012, 02:00 PM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Bucket seat under floor brace
sold if set is complete..
Old 07-20-2012, 02:22 PM   #3
hgs_notes
GEARHEAD
hgs_notes's Avatar
Yes, all three pieces sold together, just as seen in the pic.
Old 07-20-2012, 02:31 PM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Will use for my K20 build. I assume the middle secton will conform to the floor pan though it came from a blazer. If you know different let me know. PM payment details when possible. Thanks, Pete
Old 07-20-2012, 02:40 PM   #5
hgs_notes
GEARHEAD
hgs_notes's Avatar
PM sent
Old 07-21-2012, 02:44 PM   #6
chipflyer
chipflyer's Avatar
It will fit perfectly, trucks that came with buckets had the exact same piece spot welded in. A must have piece if you are adding factory buckets and want to make it just like original. This will also make it easy for you to find the seat bracket hole locations, you will find it is about an inch outside the bench seat bracket hole location.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 07-21-2012, 03:02 PM   #7
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Jeff
Good to know. I am concerned that I need another set of braces to complete the install as seen in the last pic of post #14 on this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=516328
Anyone know for sure?
Old 07-21-2012, 03:10 PM   #8
Classic Bowties
Always on the hunt...
Yes, if trying to look OE will you need the smaller rear brackets, this setup is for a blazer with rocker boxes. I had posted several A50 optioned truck floor pan pictures months ago in your above linked thread. Mel
Classic Bowties is offline   Reply With Quote
Old 07-21-2012, 03:32 PM   #9
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks Mel. This would not be a complete set then for a truck install. Bummer.
Old 07-21-2012, 09:16 PM   #10
hgs_notes
GEARHEAD
hgs_notes's Avatar
Actually, I believe these 3 pieces will work. If you have a bench seat now, you already have the outer braces front and back (they might need to be moved a bit). The ones you are needing are for the inboard mounts which are in the 2nd picture of post #14. In this case the long piece goes across the front, and the shorter pieces would be used for the inboard rear mounts.
If this isn't correct, the only way you will find the exact original style rear inboard braces is to get them from a truck or suburban that had bucket seats. Blazers are different because the seat brackets are different and the passenger side tilts forward.
Old 07-21-2012, 09:25 PM   #11
HeavyMetalChevy
Just a Member
HeavyMetalChevy's Avatar
very informative and great member!
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st)
69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd)
70 C-20 88 350 long block rebuild .040 bore. forged crank
GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum
TH400(3rd)
71 SWB frame off with 68 body. POSI
PayPal: remimartin257@aol.com
Business Inquires: 812 801 5111
"Help me, help you" that's my motto
Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog
HeavyMetalChevy is offline   Reply With Quote
Old 07-21-2012, 09:55 PM   #12
Classic Bowties
Correct, if wanting the four smaller rear floor braces to look oe truck from the bottom side view then they cannot come from a blazer. The 69-72 LH bucket seat adjuster tracks are all the same on the trucks, burbs and blazers with sport buckets, the utility style buckets had completely different tracks along with another footprint/bolt pattern for bolting down the LH/drivers seat. Mel
Old 07-21-2012, 11:43 PM   #13
70LonghornCST
Moderator
70LonghornCST's Avatar
The extent of your knowledge never ceases to amaze me, Mel. Thanks for the great info!
-Richard
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 07-22-2012, 12:10 AM   #14
sameyrasmea72
sameyrasmea72's Avatar
A correct truck uses the long brace and four smaller braces (like pic). I would sell you a set but we are out of them.....Jason
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 07-22-2012, 01:21 PM   #15
7dee2
7dee2's Avatar
Jason how about doing the forum a favor and do a write up on how to produce these. Or just share the dimensions you guys used when making them. I know this is a very popular swap (I could use 2 sets myself) and inquiring minds!!!
Sorry to high jack the thread hgs_notes..
Brett
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 07-22-2012, 05:30 PM   #16
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks for the post Jason!
Old 07-22-2012, 07:22 PM   #17
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Subscribed for the info
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 07-23-2012, 07:16 AM   #18
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Here is some picture of a truck floor board for buckets - hope it helps.
Not for sale...
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
