Old 01-12-2009, 02:53 PM   #1
tinkerdad
Rear diff cover from Jegs
I bought the Jegs read differential cover part# 720-9895 for my 12 bolt. The chrome bolts that came with it are to long, i.e. they bottom out. Jegs can’t find any thing shorter to send me. Do I have something odd? Any ideal as to what’s up with this? Thanks.
tinkerdad is offline   Reply With Quote
Old 01-12-2009, 07:17 PM   #2
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: Rear diff cover from Jegs
I have no idea how Mr.gasket sized your bolts - run the the local hardware and buy some washer head bolts that are serrated on the heads - they should be zinc plated silver and should work fine for you
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 01-12-2009, 08:17 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I'd just use a sander or bench grinder to knock a little off of the length.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-12-2009, 08:19 PM   #4
lowriden58
lowriden58's Avatar
make sure there isnt any gasket material/sealer in the threads.. this could also cause it.
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 01-12-2009, 08:54 PM   #5
orangek5
orangek5's Avatar
I had the same problem from LMC rear Diff Cover. I just used the old Bolts
1970 Jimmy 4x4 IL6
1971 Jimmy 4x4 350ci v8
1971 SWB 327ci v8
1972 Short Stepside 305ci v8
1972 Blazer 2WD CST LS9 350ci 4sp
1999 4 Door LB 1 Ton Old Body Style 5.7 v8
orangek5 is offline   Reply With Quote
Old 01-12-2009, 09:05 PM   #6
mr48chev
mr48chev's Avatar
I'm with TX Firefighter. Trim off a few rounds of threads off the end of the bolts. Or pick up some correct length Stainless bolts and polish up the heads a bit.
Old 01-12-2009, 10:06 PM   #7
C10Sim
C10Sim's Avatar
Use a vice and a bandsaw or manual one.
1968 Chevy Pickup
http://67-72chevytrucks.com/vboard/s...d.php?t=321717
1959 Chevy Apache 3100 SWB Big Window
http://67-72chevytrucks.com/vboard/s...d.php?t=597069
C10Sim is offline   Reply With Quote
