Old 06-08-2018, 08:39 AM   #1
gabbin
gabbin's Avatar
63 C10 alignment question
Does anyone know what the caster setting is. By that I mean is it positive or negative lean caster? Does the spindle lean forward or back to create the caster rate? Also, what should it be set at?
gabbin is offline   Reply With Quote
Old 06-08-2018, 09:17 AM   #2
gabbin
gabbin's Avatar
Re: 63 C10 alignment question
Pos 2°27' Caster, Pos 0°15' Camber, Toe in 3/16. Took a minute to find, hope this helps someone.
Old 06-10-2018, 07:09 PM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Thank you.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 06-11-2018, 12:27 PM   #4
theastronaut
theastronaut's Avatar
Extra positive caster will help it track straighter, so get the alignment shop to add as much as possible, especially if you have power steering. The minimal caster from the factory was to help the truck steer easier without power steering. You might be able to get 4-5 degrees with factory parts.
theastronaut is offline   Reply With Quote
