oil pan removal?
So I'm trying to replace my rear main seal on my 350, but I cant even get as far as to take the oil pan off. Its no longer attached, but I cant seem to get it out, as the flexplate gets in the way. Anyone know how to get it out?
Between Trucks...
Re: oil pan removal?
Did you undo the motor mounts and raise the motor?
Beat it to fit, Paint it to match... ![]() |
No, I dont have a cherry picker, so I'm trying to avoid doing that. Do I need to?
Between Trucks...
You can do it with a floor jack. You need to undo the motor mounts, and raise the motor so you can get some short pieces of 2" x 4"s in where the mounts are.
what do i use the floor jack on? it will dent the oil pan, wont it?
keep and eye on distributor so it does not break
![]() Join Date: Jul 2004
Hope someone else chimes in, there is certain position you can turn the crankshaft to so the counterweights are out of the way at the front making pan removal easier. I don't remember the exact prodedure.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
Between Trucks...
Factory Service Manual says to put a flat piece of wood under the oil pan and jack it up. Watch your fan in the shroud and the distributor as mentioned.
Dave's not here, man
I've always loosened the motor mounts and placed a block of wood under the harmonic balancer. Then I jack the motor up using my floor jack. It doesn't have to move up a whole bunch to work. I've never had any problems doing it this way. I'm also unaware of any issues that can arise by doing it this way. The problem with placing the block of wood on the oil pan is that you can't pull the pan. I guess you could do it that way and place blocks of wood between the motor and mounts to keep the motor raised, then set it back down pull the pan. That seems like a lot of messin' around though.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
The Older Generation
The timing mark needs to be at 6 o'clock for max clearance but I'm not sure that will help with the problem he's having.... LockDoc
Thanks Doc, I thought that was right, 6 o'clock, but wanted to be sure. Motor needs to be jacked, every little bit helps.
Designated Grumpy Old Man
![]() Join Date: Oct 2001
Turn the crank so the rotor in the distributor is pointing at the number six cylinder on the cap. This position will help the pan to clear the journels of the crank.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
What these guys said... raising the motor definately helps. I also jacked from underneath w/ a 2x4 on the harmonic balancer... then then i did it later w/o a jack & had no problems... as long as you turn the engine to the correct clock position.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
Wrench Wench
![]() Join Date: Apr 2008
Another thing to watch is your fuel line depending on your set up. When I raised the motor, it put alot of stress on the line coming from the pump. Mine was old and cracked while I had it up. I also put 2x4 blocks under the motor mounts incase the jack slipped.
If everyone had good taste, who would buy all the FORDS? ![]() Women join us!! BUSTED KNUCKLE BABES ![]() "Face it girls, I'm older and have better insurance" -Fried green tomatoes |
