Garage Queen Material
tools needed to redo front end
okay, i need a complete list of what i'm gonna need exactly to add drop spindles and coils to my truck.
me and jon picked the 28th and 29th to get my truck lowered and it would be a lot easier if we knew exactly what we needed to get the old parts off and new parts on. |
I'm back with 2nd truck!
Eric oher than reading Swervin's article I wouldn't know of anything else. But Im like you and needing a new front kit and will be reading on this as well. What suspension company did you go with?
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
really you don't need any special tools. mabey a pickle fork to break loose the ball joints but that will usualy mess the boots up and you'll have to replace the ball joints, same goes for the tie rod ends but they aren't usualy on as tight, and they make a smaller pickle for for them, but again it could mess the boots up. mike madey a tool to break his loose that didn't mess them up i think he decribes it on his site, but i won't try to explain it b/c i didn't really understand. but really basic hand tools, floor jack should do it.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
Workaholic
Same as on CT--beer (Bud). Seriously though, basic hand and air tools, jack stands are all you need---if you need an extra hand just let me know.
Rob
1979 K-10 Silverado (work in progress) 1991 V1500 Subruban 1999 Suburban LT 4x4 2006 Suburban LTZ (daily driver) |
you dont a fork to get the ball joints and tie rods loose. hit the part the shaft of the ball joint and tie rod with a hammer. if you have 2, one being a ball peen hammer it will work better and safer to prevent hitting anything else. hit on both sides till it pops loose. MAKE SURE YOU HAVE THE LOWER CONTROL ARM SUPPORTED FROM THE BOTTOM. IF THAT SPRING POPS OUT, IT COULD BE BAD AND EVEN CAUSE YOU INJURIES.
2024 Silverado Z71 PPV 1972 Chevy Monte Carlo 2018 Buick Enclave (Wifes) |
Iamnotanofficerofthelaw
Eric, is all your doing just dropping the front end? You didn't have planned to install new bushings?
Just wondering what your plans are, you say your gonna redo the front end. Thought you were going with new bushings and front end pieces.....
~Paul~ '96 C1500 Silverado- Vortec 5.0L/Exhaust/Stock ![]() '87 S-10 Ext Cab- 2.8L/700r4 KIA Caught fire 12/7/03 |
#7 | |
#8 | |
Won't he need a press if he's putting new bushings and taking old ones out of the a-arms?
You get what you pay for
![]() Join Date: Dec 1999
To remove the control arm bushings, the absolute best tool to use is a air chisel. I even took my arms to a front end shop and asked them what they used, guess what? It was a air chisel. It works like a charm.
Now to put them back in, I used my bench vise to press the new bushings in. You will need a spacer between the arm lips to keep from bending them in.
Mike 1985 Chevy C-10 |
~THE SILVER BULLET~
besides basic air and hand tools...you should be fine. but swervin is definately correct. an air chisel is your BEST FRIEND. if you dont have a QUALITY one, like a rodac...borrow, steal, buy, whatever you have to do... but get one!
~1980 c10 chevy scottsdale~ ~2.5/4 drop 305/th350c~ |
Calibration Engineer
hehe, liquid wrench is great too.. (oxy-acetylene)
