Old 02-06-2009, 08:24 PM   #1
prg machine
prg machine's Avatar
wheel bearing lock nuts
I just picked up a set of wheel bearing lock nuts for the front spindles on my k-20. I don't have a thrust washer in new set or in the can that I dissasembled with all of the old parts. The one used to set against the outer bearing cone and then the nut goes against that. Since the nuts are hardened, are they the thrust surface and there is not a washer???
The inner nut has a small pin for the lock ring to set over and they have 4 slots on the outside for a wrench. then there is an outer lock nut.
I assume the inner nut is also the thrust surface for the bearing since it is hardened?
Anyone know for sure??
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 02-06-2009, 10:03 PM   #2
prg machine
Re: wheel bearing lock nuts
any 4x mechanics ran into this question?
I do truly believe there is no seperate washer and that the nut draws up against the bearing itself. The Jeeps I have worked on through the years use a hardened thrust washer up against the bearing and soft hex nuts. The new nuts are rather tight as well. I filed the roots of the threads to help and the new nuts now fit tight but not as extreme as at first.
While we're on the subject, how many different methods of bearing load setting can we come up with??
I usualy turn em up to tight and then back off to the very first hole in the lock ring.
383 .040 over
Old 02-06-2009, 10:58 PM   #3
OLDCHEV4X4
OLDCHEV4X4's Avatar
No washer in there.
The wheel bearing should have .000 to .005 end play.
Or i torque it to 35ftlb while spinning the wheel. Then back off 1/4 turn. Then tighten till the in and out play just goes away.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 02-07-2009, 01:37 AM   #4
prg machine
thanks for confirming that there is no inside thrust washer. I figured as much since all of the parts were thrown in one can when I took it apart...............but, in my experiences , sometimes there seems to be a way that parts grow there own legs and wander off!!
383 .040 over
Old 02-07-2009, 02:29 PM   #5
OldCreek
OldCreek's Avatar
There was no thrust washer on my Dana 60 only the inner nut, lock ring, outer nut.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
