Old 02-10-2009, 12:31 AM   #1
texanidiot25
Eat My Rust
texanidiot25's Avatar
Carb loves to stay on fast idle
I have some mystery Q-Jet. Most of the choke parts were missing, but we figured it might be one that actuates on a temp sensor in the manifold. But to get it on the road we put on a manual choke cable. Not ever driving it before, dunno if that affected it, but now when driving around, when I left off the throttle the carb stays on the lowest fast idle speed setting. Right now I just tap the gas as I'm slowing down and this knocks it down to normal idle, but it's still an annoyance.
Anyway to fix this? Gets annoying when I forget to tap it off the fast idle when I shut it down and it knocks a few times more after I turn off the ignition (presumably because the motor is still spinning enough to fire a time or two more)
texanidiot25 is offline   Reply With Quote
Old 02-10-2009, 07:02 PM   #2
texanidiot25
Eat My Rust
Re: Carb loves to stay on fast idle
Ttt...
Old 02-10-2009, 07:46 PM   #3
thirdstreettito
Resident of Here
thirdstreettito's Avatar
On the front of the Q-jet there should is a screw at the bottom IIRC, it is the idle controller. Twist it while the truck is idling and it will adjust the idle. I hope I remembered it correctly.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 02-10-2009, 07:48 PM   #4
texanidiot25
Eat My Rust
I don't have a problem with my normal idle speed, it's the carb's fast idle mode for when you do cold starts, with the choke.. It has a few different fast idle speeds in the carb, 2-3 different "steps". It's constantly getting stuck on the lowest of the fast idle speeds while driving. To get down to normal idle (so I'm not wasting what ever amount of gas and vibrating the crap out of everyone's ears) I have to tap the gas hard as I'm slowing down or at a stop.
My idle screw is backed out all the way anyways.
Old 02-11-2009, 06:53 PM   #5
texanidiot25
Eat My Rust
ttt
Old 02-11-2009, 07:12 PM   #6
Maybe you need a stronger return spring. Also, it could be the rod is binding a bit at that point. Lubricate the linkage joints. I don't remember all the details of a Q-jet, I have not had one in years. But I have had the problem you mention and on more than one occassion the above fixed the issue.
Old 02-11-2009, 07:17 PM   #7
dwcsr
Hollister Road Co.
dwcsr's Avatar
Sounds like the missing parts from the choke are the issue. You still ned all of them and the choke pull off for it to work correctly. I have a Qjet that is complete with a busted flange plate, you can scavange it for parts if you want.
Old 02-11-2009, 07:22 PM   #8
texanidiot25
Eat My Rust
I'll gladly take you up on that offer. I'll mention it to my dad tonight when I talk to him.
Do you know someone who has a good usable in-cab gas tank in our area as well?
Old 02-12-2009, 12:27 AM   #9
texanidiot25
Eat My Rust
Sent you a PM
Old 02-12-2009, 10:16 AM   #10
SOUTHERN917
Wrench Wench
SOUTHERN917's Avatar
I have the same setup, and had the same problem. I increased the spring tension on the secondary, and lubed the likage. This also took care of the bog down at take off. After doing this I had to adjust the fast idle screw down 1/4 turn. The spring adjustment is at the upper linkage of the cutoff. allen set screw aims down and small screw behind linkage adjusts tension. Fast idle screw is buried under vac cut off. Hope this works for you.
If everyone had good taste, who would buy all the FORDS?
Women join us!! BUSTED KNUCKLE BABES
"Face it girls, I'm older and have better insurance" -Fried green tomatoes
SOUTHERN917 is offline   Reply With Quote
