Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-19-2009, 10:34 AM   #1
Ont67shortbox
Check my combo,please
Could someone give me some TRQ/HP numbers and a estimated 1/4 mileET please,here is the combo.
427 .030 over
TRW forged pistons .250 dome
Chev *241* oval port/open chamber heads 113cc
approx 10.6 comp
bowl work,gasket match
2.25/1.88 stainless valves
Comp solid FT 282s cam 2400-6800 rpm
244/252@.050
.590/.598 lift
Edelbrock RPM Intake, gasket matched to heads with 1" spacer
Modified 750 dp Holley
2 inch Hooker super comps/3 inch exhaust
built 350 turbo trans
Neil Chance 9 1/2 3500 stall convertor
F*rd 9 inch 4.30 gear
31 x13x15 tire
67 short box pickup weight approx 3800lbs
lowered 4 1/2F 6 R trailing arms/coil springs
block is at machine shop being cleaned,now is the time for me to adjust my combo if you think its needed,Thanks for your help
Ont67shortbox is offline   Reply With Quote
