Old 03-17-2009, 11:44 PM   #1
onlyifihadachevy
72 chevy crawler
i have a truck cab and motor and no money
How much money do you think i will need if i try to build a rockcrawler?
What parts will I need and can i get most of the parts from the junkyard?
this would not be built for events just to have fun on the weekends and be better than my friends trucks
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 03-18-2009, 01:41 AM   #2
drivethechevy
drivethechevy's Avatar
Re: 72 chevy crawler
i dont know what parts ull need but all the rockcrawlers im used to seeing at one of the shops i frequent have more the alot of custom fab time, and how the crawlers are built really depends on budget, skills, and style
deffinately invest in good axles, and for rock crawling your going to want the minimum amount of hangup spots as you can achive
i would spend some time with the rock crawlers in your area and make some connections, they will know what u need to get started and will most deffinately have some pointers for ya
good luck with the project
deffinately make a build thread once you get started cause someday i would love to build myslef a crawler
nate
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 03-18-2009, 09:39 AM   #3
Burt4x4
Burt4x4's Avatar
Buy a military or farm truck, K30. I forget what the military number is for the K30 but I would get me a 1ton4x4Chevy and a grinder/sawzall/welder/BFH etc... and a good internet connection to find a similar build that you wish yours to look like then get to work. Oh you may want to tell yer buddys to come over and help..don't forget the beer
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 03-18-2009, 09:54 AM   #4
FormerMember
M1008 CUCV
4.56 geared Dana 60 front and a 14B rear with a Detroit. 6.2L Diesel, Th400 with an NP208.
FormerMember is offline   Reply With Quote
Old 03-18-2009, 10:33 AM   #5
Burt4x4
Burt4x4's Avatar
Ya thats it!
Diesel? Smoky Joe!
Hell no, BBC all day long!
Old 03-18-2009, 05:17 PM   #6
1969 GMC
1969 GMC's Avatar
either find a cucv or just find a K30 and swap the parts over.
they will mostly have SM465's and TH400s, NP205s, and D60 front axles, 14 bolt or D70HD rear axles. 87 and newer would have TBI fuel injection.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 03-18-2009, 05:51 PM   #7
shortbed70
shortbed70's Avatar
You wouldn't want the 6.2 anyway trust me the military 6.2 suck as for the axles transmission and transfer they are worth it. I would get that some good 38" tires and some link arms from tractor supply and build a solid 3 link system front and rear and a steering ram from tsc also trust me you will need help turning those tires on a trail.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 03-18-2009, 07:44 PM   #8
onlyifihadachevy
i have been looking at some trucks and when i went wheeling this weekend a truck had a 3 link front and 4 link rear with two steerable axles. And im going to look at some more crawlers this weekend when i go wheeling
My 72 thread
Old 03-19-2009, 11:07 AM   #9
Burt4x4
Burt4x4's Avatar
I use to fix a copy machine at Seaside High
If you are ever in Morgan Hill check out Pacific Fabrication www.pacificfab.net
They have a CNC cutting table and can make anything.
If you look at the web site you can see some of the projects. The White/Blue K5/Truggy is the owners.
Anyway good luck with your build.
Burt
Old 03-19-2009, 02:16 PM   #10
onlyifihadachevy
my schools crappy as you saw, but i will check them out.
My 72 thread
Old 03-19-2009, 07:26 PM   #11
rangerfj40
Not to forget the military trucks have a 24V electrical system.
rangerfj40 is offline   Reply With Quote
Old 03-19-2009, 07:39 PM   #12
onlyifihadachevy
i like the idea of using some parts from the military trucks and theres like 10 junkyards that have at least 1 around here.
My 72 thread
