1 thing at a time is progress.
Need ideas for my inside door panels
I need some inspiration for my door panels. I've got 3 different styles to choose from. I'm thinking of not using the factory arm rest and create my own. I just need some ideas and pics.
Alan
Philippians 2:14-16 |
1961 crewcab
Re: Need ideas for my inside door panels
paint them white-or whatever your seat color is,grey?- then paint the stripe body color-orange.
the center I would cut out a piece of fiber board,1/8 inch? and then upolster it with the same material/pattern as the seat. 1959-64 impalas have a neat stylized armrest, that might be neat. if you could incorperate the door handle from those same cars (maybe by relocating the mechanism, or using one out of the same car as thearm rest), that might look cool as well. this style armrest with the door handle, is in lots of the 59-64 gm's buick , caddy , pont., chevy, and olds. there are all different lengths, depending if it is earlier, later, 2, or 4 door. |
Resistance is Futile
Shag carpet, or maybe some Troll hair
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
1962 C-10
I painted mine white and had my buddy pinstriped them for me...
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
1961 crewcab
^ that looks cheap & easy!
I have seen several different factory patterns... some with just the stripe painted white, some with the center painted white, and some with the stripe and center painted white. \/ \/ might be cool to put a cloth insert on the lower panel as well, and maybe repeat the stripe pattern... Last edited by jonzcustomshop; 03-16-2009 at 06:10 PM. |
Thanks for the ideas guys. I'll look around work for some more ideas as well.
Alan
man those are bad ass!
The price of cool aint cheap. |
It's Better With Nitro
Here are the door panels for my '63. I found a pair of door panels that weren't in such good shape (to eventually cover). I carved the arm rests from wood and attached them in just about the same spot as where the originals would mount - a little closer to the rear of the panel. Then I covered the door panels in foam and then eventually the same leather as my bench seat.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 03-16-2009 at 09:16 PM. |
#9 | |
I wish I had that kind of talent! ![]() |
VIN63 That is nice work...
Bob |
That's the nicest '63 door panels I've ever seen! What thickness of foam did you use and do you have your original pattern that I can get for the leather skin? My idea was to powder coat my panels in a black wrinkle finish along with my dash but you've got me thinking otherwise. Where can I see pics of the rest of your ride?
ABOZ |
SIR
we just went for a simple look......
66long low fleet http://community.webshots.com/user/LVNR66 |
#13 | |
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
#14 | |
Alan
#15 |
Shloooooong bed member #2
David, Daughters 66 truck: http://67-72chevytrucks.com/vboard/s...d.php?t=484601 Learning to drive a 3 on the tree: http://www.youtube.com/watch?v=CcCMvRgBo1Q Last edited by 4dranch; 03-16-2009 at 11:24 PM. |
#16 |
1962 C-10
Thanks guys! Here's a couple pics of the panels installed...
#17 |
Registerd User
Now I'm gonna have to do something with mine to. Those look cool.
#18 |
TexasBowhunter
I used 3M Adhesive spray and squeegeed fabric on mine.
Build in progress for son's first truck. |
#19 |
![]() Join Date: Oct 2006
SWEET !!!
Hey Vin how about a "how to"?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
#20 |
I think a person has to know what they're doing to write a how-to.
![]() Here's kind of what I did: It was a total experiment on my part to see if I could cover the door panel in the same leather (leftover) from my seat. I used 2x4 lumber and carved mirror images of the arm rest shape that I thought would be functional. I wittled out the recess for the pull insert. I bolted the arm rests to the panels and used some old sheets I was using a drop cloths to make my patterns. My mother-in-law stitched the a two-piece pattern for the arm rest bulge and then I trimmed the sheet for the overall pattern and marked the decorative stitch patterns. I then started to trim the foam around the existing shapes of the panel, leaving gaps to accentuate the center embossed pattern. Then I proceeded to get a buzz from the fumes of the spray adhesive. ![]()
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 03-17-2009 at 07:42 PM. |
#21 |
SIR, looks good, more pix of the interior? Looks like you have a good looking combo going in there.
#22 | |
#23 |
Phone's ringin Dude.
![]() Join Date: Mar 2007
Man-o-man, those are B A D !
![]() ![]() 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
