Old 03-22-2009, 02:14 AM   #1
jbristo67
resident oilfield trash
jbristo67's Avatar
My TH350
My turbo 350 that I picked up today has a plug on it like a 700r4. What is it and how do I make it work on my 67
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 03-22-2009, 05:24 AM   #2
JimKshortstep4x4
Re: My TH350
Depending on the year of the transmission the "plug" could be part of the TCS systems that were put onto vehicles. If it is then the transmission "plug" was for signaling the TCS system when the transmission was in high gear.
I am not sure what other function a "plug" would have on a TH 350.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-22-2009, 10:18 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: My TH350
the TCS plugged in by the cooler lines.
Does the TH350C have the plug he is describing?
Old 03-22-2009, 10:19 AM   #4
clay68c10
clay68c10's Avatar
Re: My TH350
I think the lockup 350C has that plug. It engages the torque converter clutch.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 03-22-2009, 01:14 PM   #5
jbristo67
jbristo67's Avatar
Re: My TH350
SO what do I need to make it work????
2011 Nissan Armada
Old 03-22-2009, 01:46 PM   #6
Boog
laying low
Boog's Avatar
Re: My TH350
I have one too. From what I can find we will need the plug in, vacumn/electric solenoid on the firewall and a cancel switch on the brake pedal and a fused power lead of course. I checked with a local trans man and he said I could not use this trans with a regular converter without making some change inside and could not run it without the converter switch hooked up or it would burn it up. I'm lookin to rebuild my plain t350 instead.
Bill, Palf 70 step, has one of the 350C trannys in his though I don't know if he has driven it or has the converter hooked up.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 03-22-2009, 05:34 PM   #7
jbristo67
jbristo67's Avatar
Re: My TH350
Its on the opposite side of the coolant lines. It is out of an 81 GMC pickup
2011 Nissan Armada
Old 03-23-2009, 01:33 AM   #8
jbristo67
jbristo67's Avatar
Re: My TH350
What if I just Dont hook it up
2011 Nissan Armada
Old 03-23-2009, 01:18 PM   #9
jbristo67
jbristo67's Avatar
Re: My TH350
2011 Nissan Armada
Old 03-23-2009, 03:27 PM   #10
Longhorn Man
Re: My TH350
then your converter will slip a bit more than you want and build up some added heat.
Won't kill your tranny real fast, but not good for a long life either.
Old 03-23-2009, 03:37 PM   #11
jbristo67
jbristo67's Avatar
Re: My TH350
Just talked to the tranny shop they said no big deal will just run 200 or so rpms higher in 3rd. I can live with that
2011 Nissan Armada
Old 03-23-2009, 03:39 PM   #12
Re: My TH350
Yes, that is what I am told. A bit more slip. I don't have mine hooked up yet, but I have the harness to hook mine up whenever I get to the rerwiring stage on mine.
Old 03-23-2009, 04:11 PM   #13
jbristo67
jbristo67's Avatar
Re: My TH350
My friend bought a truck with this tranny in it. It had been rebuilt and never run because the guy put a new cam in the motor and messed it up. Well my friend pulled the motor and tranny and gave me the brand new tranny. I was going to run a 700 but times are tight right now so I will run this one until it blows up
2011 Nissan Armada
