Old 01-29-2016, 01:04 PM   #1
Coach529
Coach529's Avatar
Mounting bags IFS/ IRS- how to handle the arc?
Ok so new to bagging and still working on this IRS project.
What is the secret to mounting bags in a IFS IRS situation where travel is an arc.
Currently by lower cup and upper plate are aligned at air out, and parallel. Looks great at air out, but I am not please with it at ride height.
The bag is rolling over the bag cup on the back side and I think it will cause issues.
Is there a rule of thumb I am missing regarding placement of the cup and upper mount, and angles?
Looks like I have a couple options. Move the top place out a bit, and/ or take some angle out of the cup.
Any thoughts??
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 01-29-2016, 04:25 PM   #2
Coach529
Coach529's Avatar
Re: Mounting bags IFS/ IRS- how to handle the arc?
1949 Chevy 3600
Old 01-29-2016, 11:02 PM   #3
youngrodder
youngrodder's Avatar
No expert...It almost looks like the top of your bag needs to be inverted toward the frame rail more. In other words if you look at the 2nd pic you attached the bottom of the bag is out further than the top of the bag. This would keep the bag from rolling over. I think you either need to move the top in or move the bottom of the bag mount out towards the spindle.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-29-2016, 11:17 PM   #4
Advanced Design
Advanced Design's Avatar
Same here I am no expert and someone with more knowledge hopefully will jump in.
Thinking logically...I hope...the mounting surface of the upper and lower plates should be parallel to each other at ride height. Thinking this just based on this picture of a front on bags and movement through arc. And flat to the earth may not be the best angle for both...maybe 30 degrees...
Coach, just thinking aloud here... I will step aside for smarter folks.
Advanced Design is offline   Reply With Quote
Old 01-29-2016, 11:30 PM   #5
Coach529
Coach529's Avatar
To be honest I am a but stumped.
Fought it most of the evening. Moved the top plate out and then took about 1/2 the angle out of the cup. Pretty much same results. Looked great aired out, but the bag looked really stressed at ride height and above. Finally went back to straight cup and aligned the cup and top plate while at ride height. Looks great at ride height and above. Not so pretty aired out.
Current set up is bag cup and top plate are parallel at ride height.
Aired out
Ride Height
Max Height
1949 Chevy 3600
Old 01-29-2016, 11:31 PM   #6
Coach529
Coach529's Avatar
If I cut the top of the cup down an inch it will be the same diameter as the bag bottom. Then there is nothing that can really hurt the bag when aired out.
1949 Chevy 3600
Old 01-30-2016, 12:33 AM   #7
Coach529
Coach529's Avatar
Something I just thought of. If I increased the diameter of the top of the bag cup, say to 8" it would support the bag at air out. The it could not roll down......
Hmmmmmm
1949 Chevy 3600
Old 01-30-2016, 12:35 AM   #8
Coach529
Coach529's Avatar
1949 Chevy 3600
Old 01-30-2016, 05:56 AM   #9
Advanced Design
So the bag is the bump stop? The bags in the bottom picture look ok aired out. What's different?
Old 01-30-2016, 10:32 AM   #10
Coach529
Coach529's Avatar
The biggest difference I can see is the bag is supported underneath.
1949 Chevy 3600
Old 01-30-2016, 11:10 AM   #11
Coach529
Coach529's Avatar
I came to the conclusion that a lot of my problem was that the bag was not supported underneath.
I did a temp install last night and felt a lot better about it.
1949 Chevy 3600
Old 01-30-2016, 11:24 AM   #12
'68 Newtricks
'68 Newtricks's Avatar
I would say try to mimic the picture in post #2. The upper bag mount has more angle on it and is NOT right above the lower mount. Seems your IRS mounts are a little closer to that design. Also looks like your front LCR rides at a much steeper angle while air out than all the other pictures.
Just coming in with fresh eyes, but I've never had a bag suspension. :/
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 01-30-2016, 11:27 AM   #13
'68 Newtricks
nice
can you offset the lower mount more towards the spindle? Might get even better, dunno
'68 C10 SWB
'85 K30 Blazer
Old 01-30-2016, 08:43 PM   #14
PGSigns
PGSigns's Avatar
I think this is a place where a shock wave would be a better solution. Not all suspension systems lend them selves to the swap in of an air bag for the spring. They were never designed for the amount of travel the air bag can run them through. You need to look at what the limits of the usable travel that the system you have really is capable of and design around those limits. As short as the arc is to use that type of bag is going to have some short limits.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-30-2016, 09:09 PM   #15
SCOTI
SCOTI's Avatar
If it was mine, my priority would be to set it up so the bag is as close to upright as possible @ ride height where it is most important & will spend the most time.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-01-2016, 12:52 AM   #16
Longhornss
All of you pictures in post #5 tell me you lower bag mount needs to be moved closer to the outside of the control arm, as new tricks and youngrodder suggest.
Longhornss is offline   Reply With Quote
Old 02-01-2016, 11:03 AM   #17
Coach529
Coach529's Avatar
I agree, but my concern with moving the bottom bag cup towards the wheel will only make the angle of the bag more severe at max height.
I feel the set up is adequate at air out and ride height which is where the bag will spend 95% of it's time.
1949 Chevy 3600
Old 02-01-2016, 11:04 AM   #18
Coach529
Coach529's Avatar
I think that is the what I have now. Thanks!!
1949 Chevy 3600
