Old 03-27-2009, 02:05 AM   #1
84 400
Sb 400 club
84 400's Avatar
Cool conveting an Np203 hub question
Well At the advice of dirtylary and mudder among others I think I am going to convert my np203 into a part time transfer case. I drive the truck mostly on the street and I think that it would be beneficial.
I looked it up on summit and for 44.89 I think the kit is worth the money. Now this is the mile marker part number 501 kit that replaces the "spider gears" in the t case and not the shaft replacement kit.
the other kit part number 502 includes mile marker hubs. this kit is 105.00 from summit.
The other kit replaces the entire shaft. I am planning on a 33 max tire and as I said moderate wheeling
My question is about hubs....
Should I be looking for a different set or are these worth the extra money. I am a big fan of warn hubs and have them on my willys with no complaints. Ofcourse those hubs are from 1958 and I suspect utilize better components.
So I am asking is there a better hub I should be looking for or are the mile marker premium hubs good? the truck will see moderate wheeling and street driving.
Thanks for any input.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 03-27-2009, 09:04 AM   #2
msgross
msgross's Avatar
Re: conveting an Np203 hub question
I have the milemarker hubs but haven't wheeled (or driven for that fact) yet. It's really about price in your situation. Do you want to spend $200 for the WARN premium or $65 for the others?
It never hurts to go big but I doubt that you would have any issues with the MM's. There are other weak points in a 1/2 ton setup that will break if you drive to hard (U-joints, differential, axle shafts etc..)
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-27-2009, 09:09 AM   #3
FormerMember
The MM hubs are fine for what you want to do.
Could also check Ebay for used Warns... they carry a lifetime no questions warranty.
FormerMember is offline   Reply With Quote
Old 03-28-2009, 06:26 PM   #4
OrrieG
OrrieG's Avatar
I converted by 203 in 1985 using a Doug Nash shaft kit. The ones now use the same design. The less expensive Mile Marker kits use a very thin wafer bearing that when it wears allows the internals to shift. Under load this can cause bad things in the case. The shaft kit makes it a true in or out box. I picked up 2-3 mph in town after it was installed.
All I use are Warn Hubs. Had them on our Jeeps in the 60's and what I put on my truck. I got one set replaced under warranty, it had the old retractor set up that would not disengage all the way. The replacements have a better set up. For around town the less expensive will probably be ok, but if you are using them, Warn premium (all metal) are my recommendation.
