Frustrated
just had my starter replaced and right after the truck started making a grinding noise when you start it. (same noise it makes when you turn the key when the engine is already running). so this means the flywheel right? is this something the mechanic could have done wrong when installing the starter? now it will not start at all? pushed it over to a neighborhood shop. whew... and he is replacing the flywheel/pressure plate. I also had a leaky rear seal so he is doing this as well when he is back there. is that rear seal a one piece? what would you expect to pay for this repair? thanks.
Justin
76 Chevy Fleetside 63 Lincoln Continental w/ Ford Racing 460 (550hp) 2012 VW GTI 2013 Escalade 2008 Harley |
Re: Frustrated
mechanic is stating around 6 hours labor here. does that sound correct?
Cheyenne Super
Re: Frustrated
Was a standard shift starter installed? it will cause that same problem.
It may not have been shimmed right either. |
Re: Frustrated
not sure? he just replaced the starter? the complete assembely. didnt do this before though?
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Frustrated
alot of time its just shimming the starter
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Re: Frustrated
It sounds like you have a shim problem. It's a two piece seal if the engine was built before 86 and one piece after that.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
