Old 04-12-2009, 08:26 PM   #1
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
stereo
well i finly got fed up with the stock stereo and i got a aftermarket one for free but now how do i get it too fit is there like a right up for it or anything cuz i cant even get the old one out
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 04-12-2009, 09:19 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: stereo
unless you stick it in the glove box or make some kind of mount for it you will have to cut the dash to get it to fit... there is a bolt underneath the dash and the two nuts on the radio knob shafts to remove your old one.. you may want to invest the bucks in the kit that clips to the existing wiring so you dont have to cut your harness too
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 04-13-2009, 01:24 AM   #3
AceX
>130dB Moderator
AceX's Avatar
Re: stereo
AFAIK, there isn't a kit that doesn't require cutting for our trucks, but I may be wrong.
You will need an install kit though. Some ABS plastic wouldn't hurt either...
Check out the "Truck Audio" section for a wiring diagram.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 04-13-2009, 07:07 AM   #4
pokethesmot
Re: stereo
what kit do you have
Old 04-13-2009, 08:10 PM   #5
AceX
>130dB Moderator
AceX's Avatar
Re: stereo
Standard 1-DIN mounting "cage", trim ring from Pioneer, and some custom cut ABS plastic. There's a small mounting bracket on the back side of the unit as well for added support.
The head unit comes with a wiring harness that was spliced into the factory harness because there simply wasn't/isn't a plug-and-play harness available.
Living Life @ 130dB
RIP El Jay
Old 04-14-2009, 03:42 AM   #6
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Re: stereo
I can install one without all that plastic and other hobby lobby stuff, but I notch the trim little bit. The ones I've done look perfect but it took more time than a audio install shop would want to spend.
You can do it, but you will have to cut the dash and bezel.
Try looking for the same bezel as yours at the junkyard, but with the hole for the stereo allready cut out, that would save you some trouble.
Use the cage to mark the area you want cut out, but make sure it will line up with the hole in the bezel.
I usually cut the top and bottom of the area, then fold the metal "flaps" back to the inside.
I think there is a plug n play adapter like Rusty said, but are your original speakers worth useing?
Poke, don't try to use a hand saw or tin snips, it will look retarded.
heavychevy79 is offline   Reply With Quote
Old 04-14-2009, 09:41 AM   #7
pokethesmot
Re: stereo
well i got my old stereo out and yeah my speakers are worth using there new but ive found a place to mount the stereo its gunna be a surprise
Old 04-26-2009, 04:44 AM   #8
heavychevy79
Cheyenne Super
Re: stereo
Poke, have you finished the stereo install?
I'm getting antsy for the surprise.
Old 04-26-2009, 06:12 AM   #9
pokethesmot
Re: stereo
oh yeah its all done and i have a custom fiber glass box too also i just got done the other day ripping out all my rubber mat and bed lining the floor i just have to find some batteries so i can take some pics
Old 04-26-2009, 12:15 PM   #10
pokethesmot
Re: stereo
well i snapped a pic of my stereo and it isn't fully finished cuz i still need to put that black thing around it that hides the edges and i am probably snap the pic of the custom fiberglass box later but here is the head unit
Old 04-26-2009, 12:52 PM   #11
heavychevy79
Cheyenne Super
Re: stereo
Dude that is awesome, I am surprised!
I've never seen one put there.
You just need some zip ties and split loom to clean up the wiring haning down.
But what about the old radio hole?
Old 04-26-2009, 01:06 PM   #12
pokethesmot
Re: stereo
yeah i was gunna do that today lol and im putting a cb/pa system in that hole
Old 04-26-2009, 01:20 PM   #13
pokethesmot
Re: stereo
here is my sub
Old 04-26-2009, 03:29 PM   #14
bumslie75
bumslie75's Avatar
Re: stereo
Looking good i like where you put the deck. Did you make the speaker box yourself
bumslie75 is offline   Reply With Quote
Old 04-26-2009, 03:29 PM   #15
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: stereo
i love u and all pokes..
but that is the scariest looking sub box he he he
where's yoru amp hiding?
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 04-26-2009, 03:38 PM   #16
pokethesmot
Re: stereo
in the bottom right corner of the pic you can see the corner of it lol
Old 04-26-2009, 03:39 PM   #17
pokethesmot
Re: stereo
thanks man and naw my brother Andrew made me the box its was the first thing he ever fiber glassed
Old 04-26-2009, 04:46 PM   #18
pezzy
pezzy's Avatar
Re: stereo
I skipped the extra piece of plastic route and just fit it in where the old radio was...
just ignore the dashboard (that's next on my list)
pezzy is offline   Reply With Quote
