Hows it going! I'm new to the forum and I have 1977 silverado SWB. I want to lower the truck, but I'm not sure what set up to go with. I have seen the old set up with spindles and drop springs in the front, then hangers, shackles, and a flip kit in rear. But now they have lowering control arms and lowering leaf springs....I later want to put some 20''s - 20 x 8.5 front and 20 x 10 in rear...ANY SUGGESTIONS? Thanks
Re: What's the best 5/7 drop set up?
i prefure drop lower control arms and springs, they dont push the wheels out towards the fenders like spindles do.
![]() Join Date: Dec 2008
if you do drop lower control arms do you have to change the stock upper control arm?
Happy to be here
![]() Join Date: Mar 2000
It's just a matter of personal preference on how you go about it. If it were me, I would look at the Summit Racing website and get your credit card out. Buy a set of DJM 3" spindles, and Summit brand 2" springs. For the rear I would use a DJM or Summit brand flip kit.
BTW- Did you just buy this truck? I saw one that looked just like it on Craigslist about a month ago.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-18-2010 at 10:03 PM. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Front:
3" Belltech Spindles 3" Summit brand drop springs. Rear: Flip kit Rear Shackle Bolt in c-notch Drop shocks and a sway bar up front with good bushings.
#7 | |
![]() Quote:
Man, I have followed N2TRUX ever since you came out in classic trucks magazine...Your 77 has been my inspiration....thanks N2TRux is one of the best looking trucks I have ever seen! |
Thanks for the info, so then if I get a flip kit I need to get the shackles and hangers as well. or just the shackles.
#9 | |
The longer rear shackle will lower the rear an additional 1"-2", (since there are two sets of holes). The "shackle hannger" kit is for people that only want to lower the rear 4". If you combine the "shackle hanger" kit WITH the flip kit,... you will end up with approximatel a 10" rear drop. TOO much. It can be done,... but you'll be cutting the bed floor and adding a Step notch to your frame. I don't think you'll get the front low enough to match the 10" drop. Look around in the suspension section. I think a 5"/7" drop is perfect on these trucks. If you get them too low up front you will need to pull your inner fenders. Also,... what are your plans for wheels? Those 8" ralleys may need to be swapped out (to a 6.5" or 7" ralley wheel) up front,... if you get too low.
#10 | |
Don't skimp on front end service parts either. Fresh ball joints, tie rods, and a-arm bushings will make a big difference in how the truck drives and rides after you drop it. I know you said the truck is a low-miles survivor but it is 30-something years old. I had a truck dropped with control arms and drop springs - it was a complete Chisolm suspension package (upper and lower arms, springs, drop rear leaf springs and shocks). The complete kit was crazy expensive but it was really easy to install and the finished truck rode and drove sweet. Really don't want to spend that kinda money again, next time I'll probably go with spindles / springs / flip and see how that goes. |
![]() Join Date: Feb 2010
If i where you i would look into the Eibach systems...... they are a little more expensive then all the summit and belltech equipment..... but the eibach warranty is better than all(1million mile warranty.......cant go wrong with that)
Slots go on anything!
That is a really nice truck. You might also check with CPP Jeff in the suspension forum. He can set you up with lowering parts as well.
1974 Jimmy- 5.3/4L80e/NP241 |
That's a nice looking truck 77trailering. Welcome to the boards. Looking forward to the progress on your already good looking truck.
#14 | |
Happy to be here
Thanks for the kind words regarding my truck.
#15 |
beautiful truck man... i thought it was mine at 1st! they could be twins
![]() and welcome aboard ![]()
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
#16 |
#17 |
The Cheesiest
![]() Join Date: Aug 2008
X3!!
Check into McGaughys! the LMC truck rides great!! |
#18 | |
OK, your awesome, thats what I'm going to do. I will go with the spindles and springs. then in the rear with flip kit and shackles..thanks again. On the wheels I am planning to go with some 20's 20x8.5 front and 20x10 rear. but wheels are going to have to wait....you know what a mean..lol |
#19 |
Thanks, I will look into it, but as of right now I think I will most likely end up going with the spindle and springs set.
#20 |
#21 | |
I just order the entire brake system pads,shoes,drums,rotors,brake lines,hardware,and wheel cylinders....Ouch!!! My next order is the entire suspension inners, outers, pitman, etc....... Definitely a bigger Ouch!!!! |
#22 |
#23 | |
#24 |
The Cheesiest
Yup, it starts out a 4/6 but with a trim of the springs and move up of the hangers it sits low, and rides great!
