Old 04-12-2009, 08:52 PM   #1
chevymotocross
chevymotocross's Avatar
Best $15 I ever spent.... Corvette Servo!
Bought a $15 corvette servo kit which came with all the required seals. My truck is a 1987 2wd with the 700r4. Transmission was not slipping, but sluggish in the shifts, not very firm.
I was able to remove the old servo assembly and install the new one in a matter of 15 minutes. It was very easy to access on my truck, would probably be a bit more difficult on a car.
Immediately noticed a difference. Driving normally, the truck has such a nice positive firm shift. Not annoying shifts like a full blown shift kit though.
When I got on it, it chirped 2nd gear! (I'm proud of you little 305!).
IMO, a must have, and should have been installed from factory. Great for normal cruising, but it will deliver if you want to get up and GO.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
