Old 04-17-2009, 10:27 PM   #1
white72c10
white72c10's Avatar
frustrated, fuses blowing
All lights on the truck work fine until I hit the brakes then I lose tail and brake lights and the dash lights. It blows the 20a fuse every time I hit the brakes. I've removed the rear bulbs and it still blows. I replaced the brake light switch about 2 mts ago and no problems till this week. I've checked the harness in the rear and it looks fine. Any suggestions?
white72c10 is offline   Reply With Quote
Old 04-17-2009, 10:35 PM   #2
white72c10
white72c10's Avatar
Re: frustrated, fuses blowing
Update - I unplugged the harness at the rear crossmember and then when I hit the brake the headlights dim and the dash lights go out but didnt' blow the fuse with a 30 amp but smoked the 20 amp. I'm sure this means the problem is in front of the rear crossmember. what should I check next?
Old 04-17-2009, 11:19 PM   #3
Green Machine
Green Machine's Avatar
Unplug the tailight harness at the firewall connector to see if the long wires to the back are bad. Harness may look good, but worth a try. Several things it could be, but try that next.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 04-17-2009, 11:43 PM   #4
sjarrett71
sjarrett71's Avatar
Bad ground?
-Scott-
sjarrett71 is offline   Reply With Quote
Old 04-17-2009, 11:56 PM   #5
Longhorn321
Size Matters
Longhorn321's Avatar
My guess is that if it's not the brake light switch and its not in the rear harness, it's in the wiring from the brake light switch to the rear harness. I don't see how it could be a bad ground. You might have better luck tho if you pose your question in the electrical section. Those guys are pretty familiar with these trucks and their wiring.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline   Reply With Quote
Old 04-18-2009, 12:24 AM   #6
kamikazekyle05
kamikazekyle05's Avatar
Do you have upgraded lights, maybe its drawing alot of power?
kamikazekyle05 is offline   Reply With Quote
Old 04-18-2009, 01:01 AM   #7
fixit-p
fixit-p's Avatar
you have a short to ground if you unplug the firewall harness as green machine says you could narrow it down to either in the cab or between the cab and rear cross member also if you've done any work on the chassis lately you might check there first.
fixit-p is offline   Reply With Quote
Old 04-18-2009, 05:29 PM   #8
white72c10
white72c10's Avatar
Can anybody show me a pic of were the harness is at the firewall? I'm not sure what I'm looking for.
Old 04-18-2009, 07:04 PM   #9
68gmsee
Active Member
68gmsee's Avatar
Check next to the left of the brake master cylinder looking from the front of the truck.
68gmsee is offline   Reply With Quote
Old 04-18-2009, 07:08 PM   #10
68gmsee
Active Member
68gmsee's Avatar
Here's a better one.
Old 04-18-2009, 07:10 PM   #11
Green Machine
It hooks up under the dash near the heater, might be easier to unplug from inside the cab.
Old 04-18-2009, 07:41 PM   #12
white72c10
white72c10's Avatar
Does that harness actually unplug? I found it on both sides of the firewall but dont' see that it comes apart.
Old 04-18-2009, 08:06 PM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
yes it does. 2 sperate harnesses
Old 04-18-2009, 08:35 PM   #14
white72c10
white72c10's Avatar
did something maybe not so smart. I can't figure this out so I wired in a switch in the panel bypassing the fuse. Held the brake pedal hoping that because there is no fuse to blow something would eventually start smoking. I held the brake for about 5 min and nothing and the switch didn't get hot. by doing this shouldn't I make the short obvious by burning something up?
Old 04-18-2009, 08:48 PM   #15
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
ummm did anyone ever think that all the brake lights also go thru the turn signals.... try leaving a turn signal or em flashers on ...and keep narrowing it done
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 04-18-2009, 09:23 PM   #16
68gmsee
Active Member
68gmsee's Avatar
Nooooooooooooooo!!!!! Good way to burn up your whole wiring harness, start a fire or worse lose your truck...
The connector will come apart. I used silcone spray after I used some Armorall to soften the rubber up. It's a tight fit and I had to use a small screwdriver. It will come off.
Old 04-19-2009, 02:49 AM   #17
Camper Power
Camper Power's Avatar
the signal switch is between the brake switch and the rear harness so it could be shorting out.
eh
1970 Chevy C20 daily driver
1975 GMC Jimmy 4x4 project
1966 GMC C10 Dad's project
Camper Power is offline   Reply With Quote
Old 04-19-2009, 11:16 AM   #18
fixit-p
fixit-p's Avatar
True the short could be in the cab...that why I think it's a good idea to disconnect the brakelight harness at the cab to narrow it down to being in the cab or between the cab and rear harness.
Old 04-19-2009, 11:24 AM   #19
Longhorn Man
bypassing the fuse to trouble shoot is a bad idea. i know I'd get fired for doing it.
Have you unhooked the plug on the firewall yet? We are pretty much giving you step by step directions on how to fix your truck.
Old 04-19-2009, 11:48 AM   #20
Longhorn321
Size Matters
How about disconnecting the switch at the column? I'm sure I have heard LonghornMan or somebody saying that that is easy enough. And I think I remember some saying that the turn signal switch is a trouble spot. To me, that would be better than seeing if the turn signals blow the fuse....see if it does NOT blow when you disconnect the switch and step on the brakes.
...WOOOO HOOOO!!!!
Old 04-19-2009, 12:15 PM   #21
fixit-p
fixit-p's Avatar
If you disconnect at the colum you've pretty much eliminated every thing except for the brake light sw and the wire runnig from there to the plug.
Old 04-19-2009, 12:18 PM   #22
white72c10
white72c10's Avatar
I disconnected the signal switch under the dash, doesn't blow a fuse but then I don't get brake lights. I still haven't got the harness apart at the firewall but I"m working on it.
Old 04-19-2009, 12:20 PM   #23
Longhorn Man
brakes and turn signals are not on the same fuse anyways.
Old 04-19-2009, 12:29 PM   #24
white72c10
white72c10's Avatar
Ok, finally got the harness at the firewall disconnected and then no blowing fuses. It's better to unhook the harness from under the dash because it wouldn't come out on the hood side. So I guess its back under the truck I go to try to find a chaffed wire or something touching the frame. Brake lights are brown wire correct?
Old 04-19-2009, 12:33 PM   #25
white72c10
white72c10's Avatar
plugged it back in and now I'm not blowing fuses anymore. Guess I must have moved what ever was shorting out. Seems like the troubleshooting job just got harder cause now I'm not sure its under the truck. THANKS FOR ALL HELP THUS FAR.
