Old 05-08-2009, 09:20 AM   #1
CPNE
Resident Curmudgeon
CPNE's Avatar
A-Arms question - Drum vs disc
I need a definative answer before I start on this disc brake conversion.
What I have:
1. 67 3/4 ton 2wd rolling chassis - stock
2. 72 3/4 ton 2wd disc spindles rotors, calipers, etc - stock
3. 72 3/4 ton 2wd center drag link - stock
What I intend to purchase:
1. 72 3/4 ton 2wd inner/outer tie rods and adjusting sleeve
2. 72 3/4 ton 2wd upper and lower ball joints
My question is:
Can I simply remove the stock drum spindles and ball joints and replace with the above? Or will I have an issue trying to get the disc ball joints into the stock drum a-arms?
I am aware that the brake lines route differently and the lower a-arm will need a bracket welded to it for the caliper hoses. Other than that is this a slam dunk?
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 05-08-2009, 11:39 AM   #2
Garage Freak
Re: A-Arms question - Drum vs disc
I'm doing the same conversion.
Does anyone have pics of the routing of lines and bracket?
Thanks,
Garage Freak is offline   Reply With Quote
Old 05-08-2009, 12:00 PM   #3
Only thing I know for sure is that the part on the arms for holding your brake lines differ on the drum vs disc. I am not positive on whether you can mount the ball jouts/spindles for the disc years on to a drum arm.
Old 05-08-2009, 12:04 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
That is the crux of my question
Old 05-08-2009, 12:15 PM   #5
nightmare
nightmare's Avatar
i've heard that the arms are the same, 67-72, but that the ball joints changed in 71 to accommodate the disk brake spindles. IIRC you can just change the ball joints in your 67 arms to the 71-72 style for the disk brakes and be just fine.
it may be different for a 3/4 ton, but for a 1/2 ton, the brake lines run on the upper a-arm, not the lower. when i did mine, i didn't have to use anything else for the brake lines. they just connected to the where the old drum brake lines used to be.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 05-08-2009, 12:17 PM   #6
rlm316
rlm316's Avatar
The upper arm is no problem, the new joint for the disc spindle just bolts right in. I think that the bottom joint should be ok as well. When I was buying all the parts for mine, alot of the parts were interchangeable from my '70 right up to the '91 donor front end. There is a major difference in the travel stops that are welded on the lower control arm. The spindle shapes are different enough that I didnt feel right not using a newer set of lower arms. Hope this helps.
rlm316 is offline   Reply With Quote
Old 05-08-2009, 12:55 PM   #7
my67chevytruck
Under Construction
my67chevytruck's Avatar
I know on 1/2 tons the UCA and LCA are the same part # for 67-72, the difference is the ball joint and the brake line mounting location. I helped talk a member on this board go through this same thing on his 1/2 ton and he did not have any problems that i recall.I would almost bet the 3/4 ton would switch out as well... Maybe Wes or someone will chime in and verify.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
