Closed Thread
Old 04-30-2009, 10:15 PM   #1
68c10guy
68c10guy's Avatar
Transmission question!!
Okay i know im stepping down here but i have a 700 r4 and im switching down to a th350. Which tailshaft on the th350 will be the same length as my 700? i think the 6 inch is what i need. Thanks in advance!
68c10guy is offline
Old 04-30-2009, 10:17 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Transmission question!!
Nope, you need the 9 inch.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline
Old 04-30-2009, 10:20 PM   #3
68c10guy
68c10guy's Avatar
alright thanks. any other things i should know?
68c10guy is offline
Old 04-30-2009, 10:23 PM   #4
Tx Firefighter
No, it's an easy swap. The driveshaft and yoke are the same. Linkage and cooler lines will bolt right up.
You're going to have to slide your crossmember, but the holes should already be in the frame to bolt it right in place.
Old 04-30-2009, 10:26 PM   #5
68c10guy
68c10guy's Avatar
So ill be able to take the existing yoke off of the 700 and put it right into the 350?
68c10guy is offline
Old 04-30-2009, 10:30 PM   #6
Tx Firefighter
Yes. The 9 inch TH350 and the 700R4 are the same length and use the same yoke. No driveline mods needed whatsoever.
Believe it or not, this is a popular swap. Back when 700r4s were the new thing on the block and sucked, I did a lot of 700 removal and TH350 installs. Guys wanted old reliable and none of that expensive overdrive stuff.
Old 04-30-2009, 10:38 PM   #7
68c10guy
68c10guy's Avatar
Thats exactly my problem. this is my second 700 and im tired of screwing with the thing. it just doesnt shift like it should even with adapter brackets. how is the kickdown cable and all attatched to the carb?
68c10guy is offline
Old 04-30-2009, 10:42 PM   #8
tim21391
tim21391's Avatar
ill trade you my turbo 400 for your 700r4
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline
Old 04-30-2009, 10:43 PM   #9
68c10guy
68c10guy's Avatar
i dont have the high hump for the 400but if your that interested i might consider selling it to you.
68c10guy is offline
Old 04-30-2009, 10:42 PM   #10
tim21391
tim21391's Avatar
im in salina not that far away..
tim21391 is offline
Old 04-30-2009, 10:45 PM   #11
tim21391
tim21391's Avatar
how much?
tim21391 is offline
Old 04-30-2009, 10:46 PM   #12
68c10guy
68c10guy's Avatar
well it probably needs rebuilt...make me an offer
68c10guy is offline
Old 04-30-2009, 10:49 PM   #13
68c10guy
68c10guy's Avatar
And if im not mistaken the bolt patterns are all the same, someone else chime in if you know for sure
68c10guy is offline
Old 04-30-2009, 10:45 PM   #14
tim21391
tim21391's Avatar
and would it bolt up to my 402 with no problems?
tim21391 is offline
Old 04-30-2009, 10:49 PM   #15
tim21391
tim21391's Avatar
100. 200? im only 18 so im not made of money let me know what ya want
tim21391 is offline
Old 04-30-2009, 10:53 PM   #16
68c10guy
68c10guy's Avatar
i know how the money thing is, im 17 so i feel your pain. but prolly closer to 225 or so. P.M. me your cell number and all that way i can get in contact with you.
68c10guy is offline
Old 05-01-2009, 12:19 AM   #17
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
no parts selling in this forum, and from a nonsubscriber to boot...
Longhorn Man is offline
Closed Thread
