Old 05-05-2009, 05:48 PM   #1
XTRMRCR
XTRMRCR's Avatar
ballast resistor?
I was wondering if the ballast resistor on my firewall is really required. The ignition wire comes out of the fusebox on the engine side then runs to the resistor and then one wire goes to the coil and the other goes to the starter.
XTRMRCR is offline   Reply With Quote
Old 05-05-2009, 06:15 PM   #2
El Jay
Gone to greener pastures
Re: ballast resistor?
Check the voltage coming from the fuse block to the resistor.
Originally, on these these trucks there was a "resistor wire" that went directly to the coil that dropped the voltage to the coil to roughly 9 V.
If the wire you now have going TO the resistor reads in the 13V range, then, yeah, you need the resistor that's on the firewall.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 05-05-2009, 07:51 PM   #3
cdowns
cdowns's Avatar
what year truck? does it have a points style ignition?
Old 05-05-2009, 08:01 PM   #4
fdbdw
fdbdw's Avatar
If your using points then ya you need the resistor. The one comming off the starter gives you 12v while cranking and then the resistor nocks it down to 9v while running, if you had 12v full time you run the risk of burning your points, if your using hei then the resistor is not allowing your dizzy to work at its full potential, so if its hei the only wire you need is full time 12v to your dizzy with no ballast resistor or resistor wire. so to make it simple points yes you need it, hei no you dont.
fdbdw is offline   Reply With Quote
Old 05-05-2009, 08:15 PM   #5
XTRMRCR
XTRMRCR's Avatar
It is on a stock 68 307 with points. I am going to be adding a conversion kit soon, either a Pertronix or similar. I assume I would bypass the resistor and add a 12 gage wire directly from the fuse block.
Old 05-05-2009, 11:17 PM   #6
ERASER5
ERASER5's Avatar
Check the wiring for the Pertronix, some of them use a ballast resister.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 05-07-2009, 01:48 PM   #7
smn69
I put a pertronix into my 69 307. It works great and it did require the resistor wire.
smn69 is offline   Reply With Quote
Old 05-07-2009, 01:58 PM   #8
smn69
Sorry, my bad, I used the Crane Cams xr-i conversion unit. It used the resistor wire and it also has an adjustable rev limiter (that's why I got it).
