Old 12-29-2002, 07:39 AM   #1
guypm
Brake light problem/???
Anybody have any suggestion on this one ? I have tail lights when I pull the headlight switch on the dash. No brake lights. I changed the brake light switch at the pedal. I changed the brake light fuse. I also smoothed the side marker lights front and back, taped each wire individually on the side markers so not to contact each other. Any info would be appreciated. I'll probably use a tester today when i get off work. Gonna check the switch receptacle to see if there is 12 volts at the switch.
Thanks, Guy
guypm
1971 SWB Fleetside/350 performer rpm heads &intake/ holley 750dp/1.5roller rockers/MSD6a/700r4
1650stall/one piece driveshaft/3.73 open/dynomax ceramic coated headers/3chamber flowmasters/
guypm is offline   Reply With Quote
