Old 06-11-2009, 03:33 PM   #1
madaca
madaca's Avatar
steering shaft/rod
Does anyone know what size the rod/shaft is that runs through the steering wheel for a 65 chevy c10. Its the rod that you bolt the steering wheel down to. Its a stock steering wheel. Thanks
Grandpas truck, my dream.
This is my truck. There are many trucks like it but this one is mine.
65 Chevy C10 Fleetside
madaca is offline   Reply With Quote
Old 06-11-2009, 05:03 PM   #2
dallas71
dallas71's Avatar
Re: steering shaft/rod
I am not sure what size the shaft is but i have use the shaft from a 71-77 in a 66 steering column.....just have to use the nut from the truck you took it out of....
dallas71 is offline   Reply With Quote
Old 06-11-2009, 05:05 PM   #3
joe231
joe231's Avatar
the solid rod is 9/16ths I believe.....
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 06-11-2009, 07:31 PM   #4
madaca
madaca's Avatar
thanks guys this info will help me out.
Old 06-11-2009, 09:06 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I just walked out into the shop and measured the one in my truck with a digital caliper. It is .750 or 3/4 inch.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 06-11-2009, 10:21 PM   #6
madaca
madaca's Avatar
Hey thanks for that info. I am going to try to get a tap and die set this weekend so I can rethread the end that the nut goes on. I stripped mine but I think I can salvage it.
Old 06-12-2009, 05:14 PM   #7
madaca
madaca's Avatar
Hmmm. Mine seems to be 1/2 inch. I will have to see if I can rethread it.
Old 06-12-2009, 06:27 PM   #8
joe231
joe231's Avatar
oops, yeah that is correct...just checked my drill bit I had to buy for the power steering swap...that is what I get for trying to go by memory
the 3/4" is the diameter of the shaft between the column and gearbox....I realize the threads for the steering wheel are on the same shaft, but that end is machined down to a smaller size...I would guess it is 1/2-13 thread..if it is stripped too bad there might not be enough material there to re-thread it...guess if you had to you could re-thread ti to a 12mm thread and get a new nut...
CHEVY ONLY
Old 06-13-2009, 01:01 PM   #9
502tripower
502tripower's Avatar
If you can try to use a thread gauge and measure the thread pitch.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 06-13-2009, 01:48 PM   #10
madaca
madaca's Avatar
I measured 1/2 x 20 at work. I will try to find a tap and die set that has the one I need.
Old 06-14-2009, 06:55 PM   #11
madaca
madaca's Avatar
I found 1/2 x 20 die today at oreillys auto parts. Steering wheel is now nice and tight. Thanks for the help everyone.
