Old 05-24-2009, 10:15 PM   #1
mas09ts
mas09ts's Avatar
Another Gas Tank Question . . ..
Other than the obvious 67-72 blazer tank swap or a custom tank are they any other tanks which can be mounted beneath the bed, between the frame rails.
Mitch
22yrs. Young
1970 GMC Short-Step 350/TH350 Combo. . . . Sold Dec 2011
Current Project 68 Gmc "Second Chance"
Go to my 68 GMC Shorty Rebuild Thread
http://67-72chevytrucks.com/vboard/s...39#post6341739
mas09ts is offline   Reply With Quote
Old 05-24-2009, 10:26 PM   #2
mas09ts
mas09ts's Avatar
Re: Another Gas Tank Question . . ..
anyone???
Mitch
22yrs. Young
Old 05-24-2009, 10:27 PM   #3
BADSAM
J'ville Junkman
BADSAM's Avatar
I'm guessing this is a pretty long list. Suburban tanks of course, also, I had an 89 ramcharger that had a poly tank that looked like it would fit perfect.
Do you want a direct bolt in or do you mind a little fab work?
Most tanks in older cars are located between the rear frame rails, so you probably just need to get a tape measure and head to the junk yard.
Good luck.
72 3/4t Suburban 402BB (Daily driver for 8 years)
68 GTO (never ending proj)
91 Kawasaki ZX-7R
57 Chevy 210 Wagon - 9 Passenger (Wife's project-working on floorpans)
73 Corvette (17 yr old daughter's: Another project - what's wrong with me?)
53 Willys M38
BADSAM is offline   Reply With Quote
Old 05-24-2009, 10:31 PM   #4
mas09ts
mas09ts's Avatar
Good luck.
I would like to find something that would go in fairly easy, but i wouldn't mind having to make something such as the straps or so forth.
Anyone else???
Mitch
22yrs. Young
Old 05-25-2009, 04:46 PM   #5
ShortStepper
ShortStepper's Avatar
A little different question, but still in the same line. Does anyone know where you can purchase those street rod type gas fill door housings for a through the bed fill to a rear mounted blazer tank?
ShortStepper is offline   Reply With Quote
Old 05-25-2009, 05:56 PM   #6
stueber68
1968 C20 Vortec Beast
stueber68's Avatar
I've heard that you can take one from a g-van all the way up to say a 90 modeljbut I haven't tried it my self. There have been some members here who have done it.
Ugly or not it still kicks a**!
stueber68 is offline   Reply With Quote
Old 05-25-2009, 08:22 PM   #7
ATT
ATT's Avatar
I got mine from summit racing it is a 16 gallon tank. Name:  476.jpg
ATT is offline   Reply With Quote
Old 05-25-2009, 09:37 PM   #8
fishingjred73
fishingjred73's Avatar
Here is a link for the gas filler doors http://www.haganauto.com/category_s/38.htm
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 05-25-2009, 10:35 PM   #9
ShortStepper
That's it!
Thanks,
Old 05-25-2009, 10:46 PM   #10
Uwe Blab
Uwe Blab's Avatar
What do people do for a spare tire with a rear gas tank mount? I have a trapeze set up, so I don't see being able to put in a tank between the rails behind the rear axle. Has anybody ever put in a tank in front of the rear axle (not looking for the saddle bag variety)? I know there's not much room and it would most likely have to be a custom.
Uwe Blab is offline   Reply With Quote
Old 05-26-2009, 07:34 AM   #11
cdowns
cdowns's Avatar
a couple of cans of fix a flat or use the bed
Old 05-26-2009, 07:48 AM   #12
hgs_notes
GEARHEAD
hgs_notes's Avatar
This tank is from a 75 blazer. The advantage is a large tank with a low profile. They are easy to find, I got this one for $35 complete. The disadvantage is you have to move the rearmost crossmember back. It's easy enough to do, and it is cutout ont the ends to clear the bumper brackets. Mine is not installed yet, the pictures were just when I was making the crossmember change and checking the fit.
hgs_notes is offline   Reply With Quote
Old 05-26-2009, 08:17 AM   #13
roadmaSSter
roadmaSSter's Avatar
I met a guy who got a tank out of a 1980 chevy van. The filler neck comes out the side and he made it so that the side marker light flipped open on a hinge to reveal the gas cap. He said the fuel sender was compatable with the stock gauge and all he had to do to mount the tank was to shave a little bit off of the inside of the frame rails. I saw the truck. It was really a slick setup that looked like it came that way from the factory. Plus, if you still plan on using your truck to haul stuff once in a while, you don't have to empty the bed just to put gas in.
roadmaSSter is offline   Reply With Quote
Old 05-26-2009, 06:36 PM   #14
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
im using a tank from a 76 chevy van. finished most of the fab work today. ill try to post pics later
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
