Hi, Have troubleshooted "won't start" prob. No spark to plugs. Replacing the dist with a new one. My ? is do i have to find tdc before inserting the new dist. Also, the rotor is pointing toward the firewall when i tried to crank. Please advise.
Thanking u in advance frankyjoet ![]() |
1962 C-10
Re: Rotor position with cap off
You want to make sure the #1 cylinder in on TDC of the compression stroke. The rotor should be point toward the front of the vehicle, usually a little toward the driver side... 5 o'clock looking at it from the front of the truck...
If the distributor is 180 off, it usually pops through the carb.
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
