sleeved bags on rear links
I'm bagging my truck and I have enough space to run sleeved bags in the rear on the arms where the spring use to be.. I was wondering if there would pros and cons to this set up and if any one else has done this?? Also is there a website to get the specs on firestone air bags?? Thx in advance..
1969 Chevy C-10 350/700r4 |
Re: sleeved bags on rear links
It's really best to avoid putting sleeve bags on a bar. They cannot handle the misalignment that comes with it. And you need to mount them close to the axle, because they can't handle too much leverage. I have plans on a way to do it, but it requires shackles and extra link bars to keep the bag straight through the entire travel of the suspension. Simply putting them on a link bar will stress them too much. They should be mounted directly to the axle.
If you can find it cheaper, I can fix it! |
Dont know if this is what you were looking for or not....http://www.firestoneindustrial.com/n...s_sleeve.shtml
Are you looking to get more lift from a sleeve? |
thats the one thx u layframe and twisted
Ya sleeve bags are the best for bag over axle and bag behind axle...
Adam M STX Designs Motorcycles | Choppers | Hotrods |
Im not trying to be negative and really apreciate the advise and responses but whats the diffrence between behind the axle and in front of the axle? I was lookinjg at some of the 18 wheelers at work and noticed that they have them in front and they are sleved and some are Double Convoluted bags...
There is no difference if they are mounted to a bracket that is welded to the axle. It reacts and rides the same, it just depends on what kind of space you have to put the bags.
f9000's really dont have the load ability to handle being mounted in a ratio.
#9 | |
![]() Big trucks most likely have entirely different weight ranges for the size of the bags they have installed. I know we use some sleeve type bags on some of our automated palletizing equipment & dbl convoluted bags in other areas (freakin' huge dbl convoluted bags @ that).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-27-2009 at 12:04 PM. |
look at the set up im working on ...
