Old 06-01-2009, 07:21 PM   #1
CDF302V8
CDF302V8's Avatar
What transfre case do i have?
Hey Y'all,
I have a 1979 GMC 1/2 ton. What transfer case do i have?
CDF302V8 is offline   Reply With Quote
Old 06-01-2009, 07:53 PM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: What transfre case do i have?
probably a NP205, but we need more info or pics.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 06-01-2009, 07:59 PM   #3
CDF302V8
CDF302V8's Avatar
Okay, i dont have a photo of it now, but i will try to find some info...
Old 06-01-2009, 08:14 PM   #4
CDF302V8
CDF302V8's Avatar
That is the shifter it has...
Old 06-01-2009, 08:57 PM   #5
dammitmitchell
the pollock
dammitmitchell's Avatar
hey dude there should be a tag on the side held on with a single phillips head screw.. if you clean off that tag it will give you all your information
http://www.chuckschevytruckpages.com/drivetrains.html
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 06-01-2009, 09:18 PM   #6
pulltilbroke
pulltilbroke's Avatar
That shifter knob indcates a NP203, Is it a iron case with a big aluminum tailhousing and a funky linkage setup?
60 4x4,235,SM420,Rockwell T221,D44/HO33 sold 4/12
67 C-20,292,SM420,HO72
90 Dodge W250 Cummins,NV4500HD,205,D60/D80
93 Dodge W350 Dually Cummins, Getrag, 205,D60/D70
pulltilbroke is offline   Reply With Quote
Old 06-01-2009, 09:21 PM   #7
67mater
67mater's Avatar
i would bet it's not a 205 being a half ton. my bet is a 203, especially if it has the shift pattern shown in the flyer. 203 is a full time case, that's why there's not 2wd. need a pic from the back
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 06-01-2009, 09:59 PM   #8
67ZL1
From what i've read a 203 and 205 look alike. I was told the easiest way to tell is the idler shaft has a 3 bolt cover on the back of the t-case.
67ZL1 is offline   Reply With Quote
Old 06-02-2009, 12:10 AM   #9
1969 GMC
1969 GMC's Avatar
what tranny in the truck? i am guessing an auto?
since it has the 203 knob, i'm guessing 203.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 06-02-2009, 06:42 AM   #10
CDF302V8
CDF302V8's Avatar
Yeah, it has a Turbo 350
Old 06-02-2009, 06:53 AM   #11
You have a 203 if that`s the pattern you have and the same shifter.It`s full-time.Do your hubs have lock-outs?If they don`t,it`s still fulltime.If it has lock-out hubs,it has been converted(good idea).They operate off a drive chain rather than all gear.The chain can stretch and need replaced.
Old 06-02-2009, 07:53 AM   #12
Dooley
Dooley's Avatar
In stock form a 1979 with automatic transmission will have a 203 transfer case. Being a 1979 it will have the updated chain/gears which started part way through the 1978 model year. The chain is narrower and the gears have a much steeper pitch to eliminate slippage when showing some wear. GM squarebodies did not use the 205 with the automatic transmission until the 1980 model year,(all models got the 205 in 1980). GM used the 205's in 1 ton K/V models through 1991).
Dooley is offline   Reply With Quote
Old 06-02-2009, 03:45 PM   #13
CDF302V8
CDF302V8's Avatar
Nope, no lock-outs. Thanks for the info!
Old 06-03-2009, 06:13 AM   #14
Blazer1970
Blazer1970's Avatar
Originally Posted by Dooley View Post
GM squarebodies did not use the 205 with the automatic transmission until the 1980 model year.
Some did. I parted out a '73 K20 that came with a TH350/205. I am not sure if this was even an option by '79 though.
Blazer1970 is offline   Reply With Quote
Old 06-03-2009, 07:22 AM   #15
Full-time 4wd was an option.An automatic truck could have the 205 and lockouts.
Old 06-08-2009, 12:29 AM   #16
Dooley
Dooley's Avatar
Full time 4x4 was standard with automatic transmission.
