Old 06-17-2009, 02:23 AM   #1
68c10owner
68c10owner's Avatar
bad switch?
Recently the pass side power window is moving slow when I use the driver side switch. If I use the pass side switch it moves a little faster. Is my switch on the driver side going bad? Bad motor? Could the tracks just be dirty and need to be cleaned and lubed?
Anthony
68c10owner is offline   Reply With Quote
Old 06-17-2009, 02:36 AM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: bad switch?
I'd check things out in this order;
Clean and lube the regulator and the roller/channel.
Run check on the switches to insure the same voltage at both.
Run 2 test leads directly from the battery to the window motor to see if it moves faster or the same. Reverse polarity to check the motor in the other direction.
Lastly inspect the condition of the wiring in the door jambs for any breaks as they are prone to weaken and break inside the rubber boots from constant opening & closing of the doors especially the drivers side(It gets the most use.)
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 06-17-2009, 02:41 AM   #3
68c10owner
68c10owner's Avatar
Re: bad switch?
I think that pretty much covers what I need to do,lol. Thanks alot.
Anthony
