Old 06-20-2009, 10:00 PM   #1
madaca
madaca's Avatar
walmart carpet
Has anyone used the cheap carpet you can get at walmart or the auto parts stores that comes in a roll? Was wondering if anyone has used it and if it worked out ok. Was thinking of buying some to cover up the floor in my 65 chevy c10. Any feedback and pics would be appreciated.
Grandpas truck, my dream.
This is my truck. There are many trucks like it but this one is mine.
65 Chevy C10 Fleetside
madaca is offline   Reply With Quote
Old 06-20-2009, 10:12 PM   #2
64Magoo
Re: walmart carpet
just buy a roll of astro-turf!
64Magoo is offline   Reply With Quote
Old 06-21-2009, 01:00 AM   #3
Corts60
Just here to tinker
Corts60's Avatar
Re: walmart carpet
I used to use it a lot when I was a broke teenager...it works fine as long as you put floor mats down. If you rub against it too much it starts pulling apart and looks like matted sh*t. But there is nothing wrong with it. The black actually can turn out pretty nice if you take your time....
Old 06-21-2009, 01:17 AM   #4
madaca
madaca's Avatar
Re: walmart carpet
Thanks for the input there Corts60. I will be putting mats down on top of it. Maybe I will do a how to when I do it for others that are on a budget. I'll at least take lots of pictures. I first have to patch up some holes I have on the floor. One on the drivers side and one on the passengers side. Anybody else have any input or pictures of their do it yourself cheap carpet installs.
Old 06-21-2009, 01:27 AM   #5
protrash64
Resistance is Futile
protrash64's Avatar
Re: walmart carpet
I dont know what your budget is, madaca, but you mite be further ahead to get one of the original rubber floor matts that cover everything. My .02...
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 06-21-2009, 05:25 PM   #6
the lights
the lights's Avatar
Re: walmart carpet
I too was on a budget in high school. thats why I tried the cheap carpet, and as stated above it basically turned into shag carpet making it impossible to vacuum. I finally saved up enough for a kit, which was way better but Im thinking of going the rubber floor mat route this time around.
the lights is offline   Reply With Quote
Old 06-21-2009, 06:26 PM   #7
dreamtruckproject
Re: walmart carpet
You could also use the DIY bedliner, which has the added benefit of being waterproof.
63 Chevy short step
dreamtruckproject is offline   Reply With Quote
Old 06-22-2009, 09:51 AM   #8
ratskin
Re: walmart carpet
I used Ozite carpeting in my 64 Suburban-one piece front to rear, including the firewall. This stuff stretches to fit all the bumps and grooves, and holds down well with spray adhesive. I put sound deadener and foil faced(both sides) pad down, then the carpet. There's an online store called "yourautotrim" that's based in Alabama, and they have a lot of different colors.
ratskin is offline   Reply With Quote
Old 06-22-2009, 09:56 PM   #9
madaca
madaca's Avatar
Re: walmart carpet
Thanks everyone. Some very good suggestions. I will look into the rubber mats and yourautotrim for the carpet as well. I will let you all know what I decide to go with later when I begin the project.
Old 06-22-2009, 10:06 PM   #10
TwoFiftyShifter
Re: walmart carpet
My sister just did some work on her Iroc over the winter, used that carpet from walmart for the whole floor. Worked OK.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 06-23-2009, 09:05 AM   #11
jchav62
1962 C-10
jchav62's Avatar
Re: walmart carpet
I recently did my 73 with that cheap carpet. It came out okay. It will do. For $7 a roll you can't beat it. For some reason, the black seems a little more durable that other colors.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 06-23-2009, 09:09 AM   #12
frmula505
frmula505's Avatar
Re: walmart carpet
Find a carpet business and buy some remnants. You would be surprised at how cheap they will let the small pieces go for.
1961 GMC Suburban Custom
1969 Short wide project http://67-72chevytrucks.com/vboard/s...d.php?t=535479 (SOLD)
1959 Apache fleetside (frame off in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=348746
1960 Apache short/narrow shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=350780 (SOLD)
1951 Plymouth leadsled project
2005 Corvette conv. Procharged
1969 Corvette stingray
2006 Cadillac XLR-V
1950 Oldsmobile 98 custom project
frmula505 is offline   Reply With Quote
