Old 06-25-2009, 04:59 PM   #1
tucnnuts
if they can make it so can I!
tucnnuts's Avatar
bagged trucks and hanger bearings
ok guys need some help ... i am havin some problems with a bad drive line vibration...iam pretty sure it is cause the angle it is at...it is alot better with the truck raised up but still there at low speeds....i have put a slip yoke on the rear driveshaft to releave the hanger bearing, i was just wonder if anybody thinks like and heavy duty pillar block would work...somthing with out the cushion mount like stock,the cushion seems to let it vibrate to bad
tryin not to cut out the cab for a one piece shft...thanks for any info...
tucnnuts is offline   Reply With Quote
