Old 07-16-2009, 11:18 AM   #1
Green66Shortbed
Bolt choices
i have a 66 c-10 that i am replacing the clutch in, (along with the motor) and im wondering if anybody knows if it makes a difference whether or not i use the original style bolt that has a shoulder or if i can use one that is threaded all the way up to the head.
im referring to the bolts that hold the clutch assembly onto the flywheel.
Green66Shortbed is offline   Reply With Quote
Old 07-16-2009, 11:38 AM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Bolt choices
You want it to be at least a Grade 8 bolt.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 07-16-2009, 11:41 AM   #3
Green66Shortbed
Re: Bolt choices
see, thats the thing, i can use the bolts that GM gave me or the ones i have.
the GM bolts dont look like grade 8 bolts, but they have a shoulder, and the bolts i have are grade 8 bolts but they dont have a shoulder. decisions, decisions.
Old 07-16-2009, 12:14 PM   #4
Green66Shortbed
Re: Bolt choices
bump
Old 07-16-2009, 12:23 PM   #5
ray-bones
Re: Bolt choices
use the shoulder bolts. find them in a grade 8 if you can.
ray-bones is offline   Reply With Quote
Old 07-16-2009, 12:33 PM   #6
Green66Shortbed
Re: Bolt choices
i am currently replacing the clutch in my grandpas truck and we can use either bolt. i replaced the clutch in my truck and didnt use a shoulder bolt. i did use a lock washer, though.
is there any reason that a bolt that was threaded the full length couldnt be used in this situation? if it gets torqued to 45 lb ft it wouldnt be any different than a shoulder bolt, right?
Old 07-16-2009, 12:37 PM   #7
joe231
joe231's Avatar
Re: Bolt choices
I don't know why those are shoulder bolts, the clutch pressure plate assembly should be tight against the flywheel.
if it were me I would just use fully threaded grade 8 bolts....
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 07-16-2009, 12:41 PM   #8
Green66Shortbed
Re: Bolt choices
way to go, joe. this is the answer i really wanted to hear. if it were the other way i would have to tear my truck apart again and use the different bolts on my clutch assembly. i dont want to do that.
THANKS TO EVERYONE!!!!
Old 07-16-2009, 12:52 PM   #9
joe231
joe231's Avatar
Re: Bolt choices
do I win a prize?
hopefully, for your sake and mine, it is the right answer
CHEVY ONLY
Old 07-16-2009, 12:54 PM   #10
Green66Shortbed
Re: Bolt choices
do I win a prize?
well, if it isnt, we will find out soon enough. its almost ready to hit the road.
i should really start a build thread.
Old 07-17-2009, 03:03 AM   #11
502tripower
502tripower's Avatar
Re: Bolt choices
A Shop Manual is a must if you plan on doing any work on these old rigs. This should answer your question. As My Auto shop teacher Merv Hall use to say. "These automobile manufactures have spent thousands of dollars on research and development. What makes you think you can do any better". And of course we would just laugh and continue with our work. Anyway what I am getting at is use the shop manual and the Assembly Manuel. These will give you the correct information.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 07-17-2009, 03:59 PM   #12
Captainfab
60-66 Nut
Re: Bolt choices
Before I knew any better I used regular fully threaded bolts without issues. The factory bolts have the shoulder on them so that the torsional force from the pressure plate is against the smooth shoulder instead of against the threads on a fully threaded bolt.
Old 07-17-2009, 04:39 PM   #13
joe231
joe231's Avatar
Re: Bolt choices
Ah, makes sense guys.
when The OP was saying shoulder bolt I was thinking it would bottom out and allow the pressure plate to float, which I don't think would be a good thing.
CHEVY ONLY
Old 07-17-2009, 04:50 PM   #14
Green66Shortbed
Re: Bolt choices
well with this new found knowledge, it looks like the trans and bell housing will be coming back off in the next few days. at least i found this out before i was cruising down the highway. lol. i do love the learning experience, though. thanks to all you you for your help. this place is awesome.
Old 07-17-2009, 04:52 PM   #15
MacAttack
283 Drama Queen
MacAttack's Avatar
Re: Bolt choices
Stress risers (including threads) under shear are not good things. Threads are to create compression load. Shoulders take shear much better.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 07-17-2009, 10:12 PM   #16
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Bolt choices
No sense going to that much trouble. Just turn the engine around as needed and change the bolts one at a time through the bottom of the bellhousing. No need to remove the bellhousing or trans.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 07-17-2009, 10:15 PM   #17
Green66Shortbed
Re: Bolt choices
this, right here, is why i come here. *high five* is it an acceptable practice to just remove one bolt at a time and place a new one in there? should i remove them all and then reinstall and follow the pattern?
Old 07-17-2009, 10:21 PM   #18
Tx Firefighter
Re: Bolt choices
Do them one at a time and you will be fine. You might take a big c-clamp and cinch it down near each bolt to keep the pressure plate from warping away from the flywheel when you get the bolt removed until you get it replaced.
If it were mine, I wouldn't even do that though.
Old 07-17-2009, 10:22 PM   #19
joe231
joe231's Avatar
Re: Bolt choices
good idea
CHEVY ONLY
Old 07-17-2009, 10:25 PM   #20
Green66Shortbed
Re: Bolt choices
wouldnt bother using a c-clamp or replacing the bolts at all?
it wont be a problem to remove a bolt and torque it, then skip a bolt, remove the next one, replace and torque, skip, remove and torque, and so on, or would can that potentially cause some trouble?
Old 07-18-2009, 07:25 AM   #21
502tripower
Re: Bolt choices
One at a time will work just fine. Good Luck.
98' FXD
2002 2500HD
Old 07-18-2009, 09:22 AM   #22
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Bolt choices
I dont think its that crucial in using a "shoulder" bolt in this application. On my clutch I used a 3/8" x 1" grade 8 bolt, washers and Locktite.
If you must run a shouldder bolt, you can but longer bolts (so you have a shoulder) then cut them down.
However, all you would need is an 1/8 shoulder...mabey 1/4 at the most.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 07-18-2009, 10:28 AM   #23
joe231
joe231's Avatar
Re: Bolt choices
if the smooth portion is much longer than 1/8th" seems it would interfere with the clutch tightening to the fly wheel, which would be much worse than using a entirely threaded bolt, if the pressure plate assembly were allowed to float i would assume it would eat the bolts and wallow out the holes in a very short period, not to mention make some noise....
CHEVY ONLY
Old 07-18-2009, 10:48 AM   #24
Green66Shortbed
Re: Bolt choices
the grade 8 bolts i have on my clutch currently have about an 1/8 shoulder i think. i bet they are the exact same as the ones you used. how long have you had your clutch on your truck? noticed anything different?
Old 07-18-2009, 10:52 AM   #25
Green66Shortbed
Re: Bolt choices
the shoulder doesnt interfere with the tightening of the bolt, nor does it let the clutch assembly float. i think its there for the clutch assembly to sort of ride on in a way. rather than only touching a thread on the side of the hole, there is a solid surface. somebody mentioned this earlier, i think.
the flywheel is threaded completely through it so the bolts can tighten as much as they need to. there are only less threads being used since the shoulder is about 3/8 of an inch long. that would make me think that i would want to use a fully threaded bolt rather than a shoulder bolt since i would have more threads working to hold the pressure plate to the flywheel.
