Old 05-18-2002, 03:27 PM   #1
PushinPebbles
My dad's 68
PushinPebbles's Avatar
Lightbulb power steering
i have a power steering pump off a inline 6 nova i have the brackets for P/S in our truck that im going to try together now, im sure you guys/girls have been asked a 1,000 times but what year power steering box will bolt on to our frames?...................Jack
Jack M. 14
67 C-10 SWB 355 built T-350 tranny hurst shifter 15x8 &15x10in corvette rallys slammed**hopefully bagged this summer**
88 1/2 ton suburban 4x4 350/700R-4*having a 9 in lift w/ 38 in tires
69 SWB-parts
71 LWB-parts
72- LWB-parts
grand dads truck 68 C-10 stepside fuel inj. 350/700R-4*soon in audi silver*
Jack M.
67 C-10 SWB 355 built T-350 tranny hurst shifter 17x8in KMC's on michelins, clear tails and back up lights slammed**UPDATE i have decided on my bag setup and will post further info when i recieve all the parts
4 12 inch Lightning Audios
87 silverado 3/4ton jacked up 10-12 inches black and rubberized bed coating 35 in michelans ******************************
Dad's truck
68 C-10 stepside, 468 BB, tubbed, weld wheels, Nason black,lots more
84 toyota pickup 22R 5 speed 2WD slammed, shaved and all the body lines filled w/ buickGN scoop,bout to be sprayed in 2003 mustang green metallic w/ silver flames
S/N=BIGGYTYME@aol.com
(hydros)
"No fat chics, truck will scrape"
PushinPebbles is offline   Reply With Quote
Old 05-18-2002, 04:25 PM   #2
72MARIO
72MARIO's Avatar
Post
Dude its no problem I am pretty sure anything from 68-87 will fit they are all the same . Although Iam not sure of the turn ratio diffirences. Someone said that burbs have a quicker one I dont know how trus this is.
72 Chevy 350 1\2 leaf springs soon to have ps, pb, 700R 2/4 drop , 88-94 bench ,67 front clip ,Blazer tank flip down tail light gas filler
Filled stake pockets minor smoothing to fire wall and Frame shortened.posible idea of ash tray into cup holder?
[This message has been edited by 72MARIO (edited May 18, 2002).]
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 05-18-2002, 05:02 PM   #3
69 longhorn
Post
I believe it was 80 on that had the metric boxes,some are faster ratio. I fell into mine ,as luck would have it(dont usually work that way!). I parted out an 84 burb,& used the box on the longhorn. I am set in 6/250 position with my smallblock,so i used 73 up waterpump,steering pump & pulleys. It was no trouble adapting the burb box,just used the hoses for the burb,& changed the fitting in the pump. Good luck........69
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 05-19-2002, 03:34 PM   #4
PushinPebbles
My dad's 68
Post
the power steering pump looks like the one on the camaro we just built will car pumps still work work? good thing about the years cause there is 4 87 suburabans in my neighbor's junk yard, car lot, or wrecking yard jack
Jack M. 14
69 SWB-parts
71 LWB-parts
72- LWB-parts
Jack M.
Dad's truck
(hydros)
