Old 07-18-2009, 03:14 PM   #1
85sqbdy
85sqbdy's Avatar
brake problem
has anybody had this problem? brake pedal is stiff, it came down to the left front brake line had a restriction. driverside softline is collapsed. went to the parts store for new lines both sides. new brake lines hit the drop spindels and can't be installed. yes the design is different. so went to every parts house to compare them and the same thing everywhere. what now? i can't drive my truck and i'm about to lose my mind.
if it ain't broke, fix it until it is.
85sqbdy is offline   Reply With Quote
Old 07-18-2009, 03:36 PM   #2
menace121978
menace121978's Avatar
Re: brake problem
did you try routing them under the spindle? mine hit if i routed them up over the a arm but fit perfectly in between a arms.
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 07-18-2009, 05:30 PM   #3
menace121978
Re: brake problem
click on my build thread. i just finished up my lines today and i just posted a string of pics that should hopefully help you. dennis
"Dennis the Menace"
