Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-29-2008, 12:35 AM   #1
70stroker
70stroker's Avatar
supercharger
ok guys jan 15th im ordering my 177cid wieand blower. Anyone who has dont this is ther anything i need to be aware of, as far as im concerend its a intake swap pretty much. its going on my 454 bbc.
acutally my main reason for posting this is just to see come pics of blower set ups, sbc or bbc dont matter which. And to see how much difference it made to people, very noticable, kinda sorta...or....
70stroker is offline   Reply With Quote
Old 12-29-2008, 10:39 AM   #2
CoggedBelt75
CoggedBelt75's Avatar
Re: supercharger
Bet you'll have instant gratification with the WOW factor and gobbs of down low street torque!!! I know I am......
CoggedBelt75 is offline   Reply With Quote
Old 12-29-2008, 01:19 PM   #3
meansting04
meansting04's Avatar
Re: supercharger
I have heard that the extra "pull" and "wieght" on the crankshaft can be an issue. I have never had one before so i am going off of what i have read and seen.
67 gmc 1/2 ton, 5.0 v6, 4 speed SOLD!!
70 Chevy C-10, 355, th400, 3.73's 2/4 drop
meansting04 is offline   Reply With Quote
Old 12-29-2008, 04:40 PM   #4
CoggedBelt75
Re: supercharger
Not sure on the smaller blowers and belts, but on the 3" belts it can be if the belt is too tight, which I have seen happen locally on a blown Willys. He had the belt set too tight to begin with and when it heated up it got tighter and snapped the crank snout off. But is was a cast crank also. With with a good forged crank and the right amount of tension, all would have been good. I would suggest a crank hub instead of a balancer as it takes alot of weight off of the snout. Other than watching your timing and compression, it's not much different from an intake swap except this one will be adding air. Just my 2 cents....good luck on the build!! Joe
Old 12-30-2008, 05:46 PM   #5
70stroker
70stroker's Avatar
Re: supercharger
wow lookds awesome. anyone else got them on there trucks or cars?
one question can i run my flex fan i have now that has a 2 inch spacer, or will it hit the blower belt?
also do the weiand 177 sc have there own oiling system?
Old 01-01-2009, 11:39 AM   #6
blown luv
Re: supercharger
you will love the 177.I have 2 friends {brothers} that run them.1 is on a luv truck the other a vega.Make sure you use forged pistons,watch your timing.I had a 144 on mine till I bought my 671.The little blower was fun,fun,fun,but man that 671 is a beast!!!!
blown luv is offline   Reply With Quote
Old 01-01-2009, 11:54 PM   #7
70stroker
70stroker's Avatar
Re: supercharger
one of my main questions ive been meaning to ask, right now my gmc is throttle rod operated. I dont see a way the rod can run the throtle when i supercharge it. so does anyone have a part number or such and a cable operated one i can use, perfably a bolt it one.
Old 01-02-2009, 12:08 AM   #8
blown luv
Re: supercharger
most of the blower companys like wiend,bds,sell throttle kits for there blowers.
Old 01-02-2009, 12:46 AM   #9
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: supercharger
Baytown ? Luv? Who is this ?
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 01-02-2009, 10:26 AM   #10
Tmiller
slims 68
Re: supercharger
I have a 177 Weiand. I just made a braket to extend the arm and had to drill a hole in the throttle link on the carb. Took some tweeking to get the peddle just right to where it was pulling full throttle and not over pulling.
I have pictures on a post, I can't seem to transfer one here.
What cam, carb, and compression ratio you running?
68 c10 LWB, blown 454 , 550 hp & 600 tq est.
06 Chevy Cobalt SS supercharged 2.0L
08 Chevy silverado crew cab 1/2 ton 2wd 5.3L, she wont let me put a supercharger on it.
Tmiller is offline   Reply With Quote
Old 01-02-2009, 10:34 AM   #11
Tmiller
slims 68
Re: supercharger
Here we go, maybe this will work. Not a great picture. Hope you have atall enough hood.
I'm running a blower carb, nitrous cam, and an MSD with boost retard. The motor is about 8.5:1 (which i'd like to bumb to about 9:1) with Speed pro pistons. You deffinately want to go with a blower carb, I tried to tune a regular carb while I was waiting for the new one to come and it just ran awfull. You'll just have to drill a hole in the manifold for a hose barb to connect the manifold reference power valve to on the carb.
I'm using a boost timing retard just because I drive mostly on the street and I wanted it to pull timing under boost instead of doing it with just static setting of my distributer. I run 38 degrees total all in by 2800rpm, 10 degrees initial, and pull out 1 degree per pound of boost.
I hope you have a strong rear end and trans, the huge amounts of torque you'll gain will certainly test it. Burp the throttle at idle at 10mph and the hole truck twists over, cuise at 30 hammer it light the 31 tall 11.5 wide tires like a John Force burn out. OOOh yeah it's addictive!!
Old 01-02-2009, 12:24 PM   #12
blown luv
Re: supercharger
Hey hot rod 80.It's me blown luv..........a.k.a.......luvondope on the luv truck.com. You the SLOW UGLY luv truck.
Old 01-02-2009, 03:18 PM   #13
70stroker
70stroker's Avatar
Re: supercharger
timiller do you have anymore pics of the install or finished product. what hood did you run. my motor is a 8.5 cr, im gonna install a blower cam in a few weeks also. my rear is a 12 bolt gm unit, with auburn posi 4:11 gears, and c clip elimanaters, mostly stock trans with shift kit and stall. We will see how it holds up.I was thinkin about just running a 800 edelbrock, is this a bad idea?
Old 01-03-2009, 08:42 AM   #14
Tmiller
slims 68
Re: supercharger
Wish I had more pics but the truck is down to the frame and the blower is off the motor and sitting on the stand. I was running the stock hood with a large hole cut in it since the hood had a bad crease in that spot in the ridge but my plan is to either use a 6" cowl fiberglass hood or some hand made sheet metal. I would deffinatly go with a blower carb. Holley and Demon make them. The fact that these carbs have the power valve sealed off from the blower and is routed to a port that you connect to the manifold gives the carb an actual reading of what load the engine is under in return giving awsome thottle response and tunability. I have tried to tune a regular carb and it's a nightmare, and is hard on the engine because of the lean conditions it cause.
Reason: when a regular carb is on a blower the power valve sees the vacume the blower is creating so the power valve never opens on acceleration giving you a lean condition no matter how much accelrater pump you give it. Also the blower carb for our single carb app. has 50cc pumps on it which help too. Before I got my blower carb I was pissed with the performance, then after it was like night and day, Thats all I did is go up a couple jet sizes and was flawless.
Sorry so long but just trying to help you and others to not go through the pain I did.
Old 01-05-2009, 08:34 AM   #15
djracer
djracer's Avatar
Re: supercharger
That looks sweet!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-06-2009, 12:16 AM   #16
straitnate14
straitnate14's Avatar
Re: supercharger
my question to you guys is that i already have a 142 on stock 350 and i want to know if it's going to be worth my time to put a realy realy good set of heads on it and a nice bottom end in or should I just get a 6.0 truck motor and build it with a cam and headers?
ΜΟΛΩΝ ΛΑΒΕ
straitnate14 is offline   Reply With Quote
Old 01-06-2009, 12:24 AM   #17
blown luv
Re: supercharger
I have run the 144 on a 63 pick up,and my brother just put one on a 75 camaro.He has the edelbrock heads {rpm series}.Forged bottom end. He loves it! I say buy good heads and make friends with some one working at Discount tires.
Old 01-07-2009, 11:39 AM   #18
Tmiller
slims 68
Re: supercharger
If your'e on a stock cam I'd sugest changing to a blower/nitrous cam, I makes a big difference, and if you do go with heads you want to look fo ones with more exhaust flow because that is what usualy hold back a blower motor.Your stock bottom should be good to about 500hp as long as you stay under 6500rpm. I ran a stock 350 crate motor with my 177 blower for a couple of years without any problems.
Old 01-20-2009, 09:27 PM   #19
70stroker
70stroker's Avatar
Re: supercharger
took the plunge....
Old 01-20-2009, 09:39 PM   #20
CoggedBelt75
Re: supercharger
Looooking gooood 70stroker!!!!! You'll be so glad you did!!!! Joe
Old 01-20-2009, 09:55 PM   #21
CoggedBelt75
Re: supercharger
I know there already is a thread on "what your truck is used for", but what are the plans for the truck ? Street, street/strip, race only?
Old 01-21-2009, 12:39 AM   #22
70stroker
70stroker's Avatar
Re: supercharger
mainly street, take it down the strip maybe 3 or 4 times all summer. In the summer i drive it everyday, if i dont drive my harley.
454 now a blower,
th350 3600 stall
4:11 posi
ya gas isnt great...... but damn its fun
Old 01-21-2009, 01:04 AM   #23
70stroker
70stroker's Avatar
Re: supercharger
Old 01-25-2009, 09:27 PM   #24
70stroker
70stroker's Avatar
Re: supercharger
Old 01-25-2009, 10:48 PM   #25
CoggedBelt75
Re: supercharger
Coming along nicely!!! Sounds great also!! So, how was the spin around the block? Surely you have. Joe
