Old 10-26-2007, 05:49 PM   #1
Travis 8128
Travis 8128's Avatar
2wd Lift kit?
i have a 1971 2wd and was wondering if there is a lift kit out there for it. If so what kind? plz and thanks
Travis
Travis 8128 is offline   Reply With Quote
Old 10-26-2007, 05:50 PM   #2
stingray72
Red Headed Step Child
stingray72's Avatar
Re: 2wd Lift kit?
Travis
WHen I researched it the only thing available to do was use 1 ton springs to make it ride higher. I don't think an actual "lift kit" for a 2wd exists. could be wrong now though
"Dinner, the perfect break between work and drunk"
-Homer Simpson
stingray72 is offline   Reply With Quote
Old 10-26-2007, 05:54 PM   #3
Travis 8128
Re: 2wd Lift kit?
ya idk but im not just looking for a lift kit im looking for anything that will get it up in the air
that is something to look in to thanks
Travis
Old 10-26-2007, 06:13 PM   #4
chev74
Addicted to Chevy
chev74's Avatar
Re: 2wd Lift kit?
dont replace it with 1 ton springs!!! i did that and it works, but the ride is ROUGH! you feel like you have no suspension whatsoever in the front. You can order rubber spacers for your original 1/2 ton coil springs that work wonders. you will need a realignment for the front end afterwards.
For the rear put some blocks under the leafs. You could order some helper spring for the rear, but that will make it a rough ride in the rear. also, air bag helpers will work without making it rough, but they are more expensive and not necessary unless you are hauling a lot of weight
chev74 is offline   Reply With Quote
Old 10-26-2007, 06:20 PM   #5
Travis 8128
Re: 2wd Lift kit?
i know i had a feeling that it would be a rough ride if i did that thas why i said it is someting to look into
1971 c-10 lwb
"With hurricanes, tornados, fires out of control, mud slides, flooding, severe thunderstorms tearing up the country from one end to another, and with the threat of bird flu and terrorist attacks, Are we sure this is a good time to take God out of the Picture?" Jay Leno
Old 10-26-2007, 06:22 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: 2wd Lift kit?
Back in the day, when I was building AMT model cars, the height was adjusted by the placement of the axle in the blocks that went into the chassis.
On my '69, lowering was done with spindles.
It would seem that the best way to elevate the chassis would be to position the front axle stub lower on the spindle, effectively raising the chassis.
If the goal is to imitate a pre-runner, it's gonna be special-made stuff that lets you do it. I don't think there's gonna be anything available, otherwise.
Member Nr. 2770
Old 10-26-2007, 06:25 PM   #7
chev74
Addicted to Chevy
chev74's Avatar
Re: 2wd Lift kit?
i have a 74 with the lifting blocks in rear (2") and 1/2 ton springs with spacers on mine. make it sit pretty level
Old 10-26-2007, 06:26 PM   #8
Travis 8128
Re: 2wd Lift kit?
well i think im going custom cuz i have got a friend whos dad is manager of team green racing with kawasaki and he knows everybody whoknows everybody so i will probably get something custom
1971 c-10 lwb
Old 10-26-2007, 06:31 PM   #9
chev74
Addicted to Chevy
chev74's Avatar
Re: 2wd Lift kit?
use your resources if ya got em
Old 10-26-2007, 06:45 PM   #10
stepn67
Junior Member
stepn67's Avatar
Re: 2wd Lift kit?
Just go to a spring shop and get a set of springs made which have similar spring rates to what you now have, but with a couple of extra coils. This should give you about a 3" lift in the front. Anymore than 3" and you'll probably need tubular upper control arms made to clear the front suspension crossmember. Fabtech used to make the springs and upper control arms, as well as an upper ball joint spacer for the 73-87 chevy. This was easily adaptable to our trucks. But in looking at their site, I don't see the 73-87 stuff anymore.
stepn67 is offline   Reply With Quote
Old 10-26-2007, 06:52 PM   #11
mvfd70
mvfd70's Avatar
Re: 2wd Lift kit?
A guy I know used Coil Spring Specialties. He was really happy with them. I'm sure they could do some lifted springs for you. The web address is www.coilsprings.com They can do a quote on line for you, but as of right now it is temporarily Out of order.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 10-27-2007, 09:39 PM   #12
drbyrdman
drbyrdman's Avatar
Re: 2wd Lift kit?
Iam trying to find one. I have pics of a 1985 pro comp lift and the frame and everything looks the same as my 72 frame
drbyrdman is offline   Reply With Quote
Old 10-27-2007, 10:02 PM   #13
Travis 8128
Re: 2wd Lift kit?
ya it does as far as i can see
1971 c-10 lwb
Old 10-28-2007, 01:48 PM   #14
stepn67
Junior Member
stepn67's Avatar
Re: 2wd Lift kit?
Yeah, up to 87 will work on 67-72 front cross members, but you'll also need all the drag links and tie rods for 73-87. I've used stock 73-87 components on my 67.
Old 10-28-2007, 01:50 PM   #15
stepn67
Junior Member
stepn67's Avatar
Re: 2wd Lift kit?
Forgot to ask, so Pro Comp makes a kit?
Old 10-28-2007, 02:06 PM   #16
Bucky71
Re: 2wd Lift kit?
Anyone know if coil spring spacers are available for the fronts of our trucks?
Bucky71 is offline   Reply With Quote
Old 10-28-2007, 03:32 PM   #17
Bucky71
Re: 2wd Lift kit?
Travis:
Look up Rancho RS6500. They are supposed to provide 1.5" lift to the front of a C20. They have me curious.
Old 10-29-2007, 01:15 AM   #18
drbyrdman
drbyrdman's Avatar
Re: 2wd Lift kit?
What is diffrent between the 72 and 73? It looks all the same. Even in the LMC catalog all of the pics are the same and some of the numbers match, but the prices are different!!
Old 10-29-2007, 01:30 AM   #19
PBFAB.COM
PBFAB.COM's Avatar
Re: 2wd Lift kit?
I purchased a 69 truck a year or so ago that had the Fabtech arms and 3" springs for the front. It also had some lifted leaves for the rear. I pulled it off to go in a "different direction". It's all on my shelf getting dusty. If you're interested shoot me a PM. It isn't the cheapest stuff... but a good way to accomplish what you are looking to do.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 08-19-2008, 01:22 AM   #20
67Cowboy
"GOD BLESS AMERICA !!!"
67Cowboy's Avatar
Question Re: 2wd Lift kit?
Any chance you still have this stuff ? Or know of a source ?!? I am trying to lift a '67 C20 with a '74 front end (disc brakes/ power steering) under it .
67Cowboy is offline   Reply With Quote
Old 08-19-2008, 01:35 AM   #21
AuggieStyle
AuggieStyle's Avatar
Re: 2wd Lift kit?
YOU SHOOTING FOR THIS LOOK????????...........
AuggieStyle is offline   Reply With Quote
Old 08-19-2008, 01:37 AM   #22
ERASER5
ERASER5's Avatar
Re: 2wd Lift kit?
Nope. See this thread. He got Porterbuilt's parts.
http://67-72chevytrucks.com/vboard/s...d.php?t=282398
FabTec linc 2wd lift 73-98 go to the bottom of the page.
http://www.fabtechmotorsports.com/ap...3-98c1500.html
How high do you want to go? They have a 7" kit or you could used the 3" spring and ball joint angle adapter.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 08-20-2008, 03:53 PM   #23
67Cowboy
67Cowboy's Avatar
Re: 2wd Lift kit?
NO, you couldn't pay me to drive a DONK, I see them just like I see Curb Skrapers =worthless !!! I want long travel control arms (A-frames/arms)for a light weight high clearance 2 WD truck < I'll post a couple photos below.
Old 04-08-2010, 10:15 AM   #24
hardcore4life
hardcore4life's Avatar
Re: 2wd Lift kit?
So what would you recomend for a truck that has 4 wheel coil springs?
hardcore4life is offline   Reply With Quote
Old 04-08-2010, 08:32 PM   #25
gkesseru
gkesseru's Avatar
Re: 2wd Lift kit?
When I bought El Scorcho (PO named it) it had 3" aluminum lift spacers at all of the body, radiator support panel, and and bed mounts. (2WD coils all around). PO had to extend the master cylinder brake lines and extend the steering shaft. No other mods that I saw. He extended the steering shaft by drilling out the shear pins in the middle and drilling new holes. Remember that when you do this, the bumpers stay with the frame.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
