firewall clearance
So I got my cab on the frame and to my surprise, my 29.5" tall tire just barely hits the firewall when the steering is turned. With all the reading I do here, I cant recall too many, if any at all, other people running into this problem. I have 3" belltech drop spindles, 1.125"-1.25" (cant remember) chopped crossmember, and air ride tubular arms. I wanted to shave my firewall anyway so the clearance problem will be solved by doing that, but I'm just wondering if a lot of others have run into this issue? (and yes, I know, a dropmember will move the crossmember 1" forward...)
Re: firewall clearance
I ran into this problem but mines doored. I'm just shaving the firewall back like you mentioned....
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
funny you responded. I've been waiting to see yours finished. I was looking at your post last night to see if you made any progress yet.
Here is what I am thinking...I think the completely flat look is a bit plain, so I was going to make a step with a bead roller where the stock firewall would have previously popped out. Kind of hard to explain but you may get the idea. What do you think? |
#4 | |
Seņor Member
Or, if you don't want to go to that kind of effort, the standard trailer fender mod will work... just cut them into the floor/firewall area behind the tire and you'll have the turn clearance you need. I only have 27" tires, so I didn't need much (and now need nothing after having gone to the DM).
#5 | |
Seņor Member
Yep, you've got to have some kind of dimensionality to the firewall or it ends up looking like a billboard. Here's a shot of my cab from some time back, showing the wheel notches (and the lines I created/left in the firewall).
#7 | |
i think it should look good, im going to do the flat look because you wont really see it with my ideas for the wheel wells/hood area....
Well I also have 29"+ fronts and a DropMember (C4) and I will still need to cut a bit out to clear tires turning when on the ground. I just picked up my English Wheel and Power bead roller yesterday from Lazze and will be using it on the entire Engine bay once I get to that stage. I have a few builds to do first but it will happen some day
![]() Kevin LFD Inc. [IMG] ![]() [IMG] ![]() [IMG] ![]() Last edited by Rokcrln; 08-09-2009 at 11:53 PM. |
It'd be alot cooler if you did
Kevin-
Are you going to be making some inner fenders with that English wheel? |
Question...I want to order some sheet metal for the firewall. Should I get 16 or 18 gauge? I'm thinking 16...
I would use as thick as possiable... it's structual and you're going to be hanging your master cylinder off it on the inside aren't you? My firewall is 1/8" thick on the driver side.
yes, I'll definitly reinforce the drivers side where the brake assembly will go.
