Old 08-04-2009, 05:36 PM   #1
Northern lights
IDing transfer case
I have a divoced transfer case that need a seal but I don't know what it is exactly. It's IN a 64 chevy but is not original to the truck. I don't see any numbers on the case itself but all of the endcaps seem to bear numbers. How would I go about IDing it so I can get a new seal?
Front
Rear
Northern lights is offline   Reply With Quote
Old 08-04-2009, 06:23 PM   #2
royo
royo's Avatar
Re: IDing transfer case
could you get us some pics this is a 205 out of a IN.
nickle and dime
royo is offline   Reply With Quote
Old 08-04-2009, 06:51 PM   #3
Northern lights
Pictures added.
Old 08-04-2009, 07:19 PM   #4
jerry moss
Born Psycho
jerry moss's Avatar
looks like a rockwell t-221 to me.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 08-04-2009, 08:06 PM   #5
j.kirn
You have a rockwell t-case and novac conversions has the seals and bearings
j.kirn is offline   Reply With Quote
Old 08-04-2009, 08:09 PM   #6
Northern lights
Jerry, I believe your right. I did a google search on the Rockwell t221 and what I found does look like mine. I even found a page on ovewrhauling one which covers changing the output shaft seal specifically (which is what I need to do). It is as straight forward as I thought but experience has taught me that things aren't always as easy as they SHOULD be so now I try to check first.
Cody
Old 08-04-2009, 08:40 PM   #7
Northern lights
j.kirn, thanks. I just need the rear output shaft seal and bearing cap gasket. I'll check with my local parts guy in the morning and if he can't get them, I'll call Novaks. Thanks agian.
C
Old 08-05-2009, 01:45 AM   #8
royo
royo's Avatar
yes times two
nickle and dime
Old 08-15-2009, 11:45 PM   #9
bad421
bad421's Avatar
yep looks just like mine just divorced like in the 63 3/4 ton i used to have
ASE MASTER TECH
  • 1968 K10 LT1 350,SM420,T-221 lwb fleetSold
  • 2007 Ford Ranger DD
  • 2000 Ford F250SD V10 4x4
  • 1968 Pontiac Firebird 468/TH400 current project
  • 1991 Dodge W350 SRW CUMMINS POWERED
Whole lotta fuel and a whole lotta Smoke
bad421 is offline   Reply With Quote
Old 08-16-2009, 06:45 PM   #10
justcuz
justcuz's Avatar
If I recall the bearing retainer on the back of the t-case above the rear output (above the speedometer cable) is aluminum. I had to replace mine once Back in the early 70's). I bet one would be pretty hard to find today.
The big problem with these t-cases is the rear output comes out so low and it is easy to mess up your driveshaft. They are probably hard to find now.
justcuz is offline   Reply With Quote
