Old 08-31-2009, 05:04 PM   #1
8door
Not too old to learn
Firewall hole what?
Next to the steering shaft is a hole, I think must be for a manual shift rod. My truck is an automatic, but hole is there. Could this have been a manual shift at one time, or is there a factory delete plug or cover?
1968 C10 a way to long restoration.
8door is offline   Reply With Quote
Old 08-31-2009, 05:19 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Firewall hole what?
Someone posted this sometime back. You probably can make one or order some rubber plug that used to go in those holes.
68gmsee is offline   Reply With Quote
Old 08-31-2009, 05:48 PM   #3
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
It should have had a metal plate with rubber backing held on with 2 screws covering it up for auto.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 09-01-2009, 12:41 AM   #4
8door
Thanks for the input . Clutch linkage, that makes sense.
So is it a rubber plug? That fills the hole.
Old 09-01-2009, 12:47 AM   #5
8door
Posted my replay at same time you answered.
So I'll look for a metal/ rubber plug.I wonder if it might be one that has metal fingers that snaps in place. I didn't see any screw holes in the body.
Old 09-01-2009, 02:54 AM   #6
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
I will take a picture of an extra one I have sitting around and post it so you can see what it looks like, If no one else beats me to it. And it goes screwed in ...
Edit added pictures Here are two pictures of my fire wall where you can clearly see the holes for the two screws...I forund theses pictures here on the board from other posts So I will still get you a picture of the Metal plate that goes there some time today.
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 09-01-2009, 05:41 AM   #7
JimKshortstep4x4
Since 8door's truck is a 68 the hole cover would have been a plastic snap in plug. The plastic plugs are not available so the metal plug can be used. The two mounting holes will have to be drilled. #6 hex head sheet metal screws 1/2" long is what is used in the 71-72 trucks.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-01-2009, 07:48 AM   #8
petey-pablo
"THE GREEN GOBLIN"
Jim
I Did Not know that? I guess we learn something New everyday.........
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 09-01-2009, 09:31 AM   #9
8door
Well firewall info is good I'm learning more from the pictures than just the "clutch linkage hole." Sounds like a conversation with a Proctologist
Old 09-01-2009, 10:34 AM   #10
BACKYARD88
BACKYARD88's Avatar
Ditto
-Mike Owen-
Old 09-02-2009, 10:45 AM   #11
bigdogboxers
bigdogboxers's Avatar
I have a 1970 4x4 chevy that has never converted still has original automatic tranny but i have no plug and no plate screw holes?????
bigdogboxers is offline   Reply With Quote
