Old 09-09-2009, 09:11 PM   #1
1stseries55
1stseries55's Avatar
driveshaft/pinion angle saga
need some opinions:
I am swapping a rear end from an 87 burb into my 65 GMC(leaf spring truck)
I moved the rear back approx 1" to compensate for flipping the rear above the leaf springs
with the move rearward the driveshaft still does not fit, it's close but the pionion angle would be off and the yoke is bottomed out in the tranny
I have to have the driveshaft shortened some...question is, how much?
I would think the yoke needs at least an inch to travel... then i need another 3/4 to 1 inch to set the pinion angle correctly.
so the yoke itself is 4"s long.... if i shorten the driveshaft 1.75--2"s will the 2" remaining in the tranny be enough?
what do you guys think? anyone done this on a leaf spring truck have any suggestions?
here is a pic that really is irrelevant but hey, we all like pics
Jared
USMC 1st Battalion 8th Marines (95-99)
55 1st Series 3100 (on 98 sonoma frame)
65 GMC short bed fleetside big back window
http://67-72chevytrucks.com/vboard/s...d.php?t=358493
1stseries55 is offline   Reply With Quote
Old 09-09-2009, 11:14 PM   #2
shrunken66stroker
shrunken66stroker's Avatar
Re: driveshaft/pinion angle saga
When I had mine shortened I called the shop that was doing it for me and they gave me specific instructions on how to measure it. Put the truck at ride height. Measure from the rear of the transmission, not the output shaft but the back of where the slip yoke slides in, to the flat part of the pinion flange on the rear end. They then had me subtract an inch and give them the number. Call your drive shaft shop and ask them. Everybody has different ways of doing things and they probably will too. As far as pinion angle, I've always heard 7 degrees at ride height. Don't quote that one though. good luck.
shrunken66stroker is offline   Reply With Quote
Old 09-10-2009, 12:02 AM   #3
Imperial Kustom
100% gearhead
Imperial Kustom's Avatar
Yikes! 7 degrees! No! No! No! Having worked at a driveline and differential shop for many moons, that is not right! Zero at the rear yoke is the magic number, BUT, you need to compensate for spring load while driving. Pinion angle should be 1.5 degrees down at ride height. And yes shrunk, that is the correct way to measure driveline length. From the output seal on the trans to the flat part of the yoke (where the bolt or straps go in).
Imperial Kustom LLC
Meridian Idaho.
I never stopped playing with cars, they just got bigger.
Imperial Kustom is offline   Reply With Quote
Old 09-10-2009, 12:03 AM   #4
502tripower
502tripower's Avatar
I think this will help. http://jniolon.clubfte.com/driveline...nephasing.html
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 09-10-2009, 12:27 AM   #5
Imperial Kustom
100% gearhead
Ive seen that formula more times than I can count. It always seems to cause vibration issues. We've been setting our drivelines up the same way I described for decades, and alot of them finally come back to be serviced after decades still wearing our 25 year old sticker on them. Not bashing, just saying that it has always worked very well for us.
Imperial Kustom LLC
Meridian Idaho.
Old 09-10-2009, 06:56 AM   #6
1stseries55
thanks for the response guys....
as you can see I do not have any weight on the frame ... when measuring how do I compensate for that? With more weight, the rear will move right?
Is it enough to make a difference?
thanks
Jared
Old 09-10-2009, 07:21 AM   #7
loco64
loco64's Avatar
hey imperial. what if you have a four link? Do you want 0 at ride height or 1.5 down still . thanks
loco64 is offline   Reply With Quote
Old 09-10-2009, 11:36 AM   #8
shrunken66stroker
Thanks for following up. Sorry for the misinformation. Like I said, don't quote me on that one. I'm glad you saw that and obviously have more experience than I do with drive shafts. Where the hell did I get 7 degrees? hmm.
Old 09-10-2009, 03:29 PM   #9
Imperial Kustom
100% gearhead
Loco, I'd still shoot for 1.5 degrees.
Imperial Kustom LLC
Meridian Idaho.
