Old 10-18-2009, 12:47 AM   #1
pritch
pritch's Avatar
A couple rear suspension questions
Do I need to relocate my rear shocks if I drop 2.5 to 3 inches?
How much difference is there between 'HD rear coil springs' and normal, or non-HD coils? My Panel came with only 2 options, HD fronts and HD rears. I want to drop a little, but would like a little softer ride, too. I can't decide between a static drop or bags. As it is, even the 2 inch lip pulling into my shop will cause everything that's not bolted down to jump up into the air. It's almost like no spring at all, just a solid bar.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 10-18-2009, 01:04 AM   #2
SCOTI
SCOTI's Avatar
Re: A couple rear suspension questions
It's not necessary to relocate the shocks w/<3" drop but it wouldn't hurt either. You could do non-HD coils up front & bags in the rear for a compromise that allows the capacity of the HD springs w/the ride of the non-HD springs.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-18-2009, 02:02 AM   #3
pritch
pritch's Avatar
Thanks, SCOTI. I did go with standard coils in the front, with 2.5 drop spindles. If relocating the shocks, do I need to get special shocks? Oh-one more question-can I just use the lower shock relocator, or if I go that route do I need to relocate top and bottom? I really hate drilling out rivits.
'68 Panel
'68 C-10
Ol' Green
Old 10-18-2009, 02:07 AM   #4
SCOTI
SCOTI's Avatar
I modify the stock brackets much like what's available aftermarket....
http://www.67-72chevytrucks.com/vboa...d.php?t=359399
On mine, I get about 1.5" on each end that's modified. I would guess (educated @ that) the aftermarket would yield similar benefits.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
