Old 09-29-2009, 06:09 PM   #1
67sss
67sss's Avatar
what are these and special promotions pkg on spid ?
looked at a 72 chevy 1/2t and was wondering what these things on the frame are in the engine bay. But it also had a tilt column and a good inner grille
67sss is offline   Reply With Quote
Old 09-29-2009, 06:13 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: what are these
Heat shield in the engine compartment on the frame rail.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-29-2009, 06:21 PM   #3
463
463's Avatar
Re: what are these
things on the frame are for redirecting the air flow back and down under the cab. my 2cents
Trueman
463 is offline   Reply With Quote
Old 09-29-2009, 09:53 PM   #4
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Re: what are these
Doesn't look too bad, either way. Is it running? Engine doesn't look like it.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 09-29-2009, 10:01 PM   #5
highperf4x4
Re: what are these
nuts bolts and washers..........
highperf4x4 is offline   Reply With Quote
Old 09-29-2009, 10:38 PM   #6
pritch
pritch's Avatar
Re: what are these
Wasn't there a discusion on some cable thing that keeps the motor from flopping over when the motormount breaks?
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 09-29-2009, 10:50 PM   #7
highperf4x4
Re: what are these
I'm still trying to figure out what we're looking for. The only thing I see on the frame that shouldn't be there is spark plug wires.
Old 09-29-2009, 11:01 PM   #8
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: what are these
My truck has the recall "fix" on the drivers' side. I found out on here that it is what was used with the cable to keep the engine from falling when/if a motor mount broke. Here's the recall letter, too. Don't know if the "guard" over the motor mount is there for that recall but the letter may help clarify. That shield at first seems to be related to the motor mount, but a closer look says (to me) that it is not attached to the mount. My eyesight may be at fault, if it is.
Member Nr. 2770
Old 09-29-2009, 11:03 PM   #9
leddzepp
Moderator
leddzepp's Avatar
Re: what are these
The guard over the motor mount is a heat shield, I have the same one on my truck. I believe they came on trucks with a small block engine.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-30-2009, 01:09 AM   #10
Terakilla
Terakilla's Avatar
Re: what are these
Nice truck, junk the old engine and get a LS vortec, or better find a new wrecked truck for a parts truck and use everything, Chevys are pretty simple to work on of u got a donor vehicle.
1970 Chevy C10 Short Stepside 4.3L LT
1965 Shelby Cobra AC 427 Comp Car
1965 Sunbeam Tiger 305
1984 Dodge D150 5.9L Magnum
1995 Dodge 3500 V10
1991 Ford 250 460
Terakilla is offline   Reply With Quote
Old 09-30-2009, 01:14 PM   #11
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Re: what are these
That's a 72 "Highlander" package. Those odd pieces are heat shields...not sure what they are shielding.
PICKMUP is offline   Reply With Quote
Old 09-30-2009, 01:57 PM   #12
mclairmo
Re: what are these
Aren't there plastic rivets in the steering shaft holding it together? Maybe the heat shield is to prevent the exhaust heat from melting them? Maybe brake lines?
mclairmo is offline   Reply With Quote
