Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-25-2010, 10:57 AM   #1
scatesracing
Machinist
scatesracing's Avatar
Heads up racing
My local track over the last couple of years has put together a couple heads up streetcar events... Typical stuff like 20 mile cruise, windows roll up and down, all glass , mufflers and insured.
The tire rule is killing me though. the rule reads • No Back halved, Tubbed or Mini Tubbed vehicle allowed So if you can fit it within your stock fender wells and it has a D.O.T. stamp on it your good...... even if i run a tire that fits into the stock fender well im tubbed so my truck is put into the outlaw class.....SOOOO Im thinking of putting the tubs back stock... The rule dosent say anything about the rearend being narrowed. get some wheels with the right offset and go racing.... Now to my question. what is the biggest tire we can fit in the stock fender well. the key word is "in" Im not putting a straight axle in the front.. LOL
scatesracing is offline   Reply With Quote
Old 04-25-2010, 10:12 PM   #2
djracer
djracer's Avatar
Re: Heads up racing
I had a 29.5 12.5 sportsman pro on a ten inch wheel.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 04-26-2010, 01:01 PM   #3
nxtruck
nxtruck's Avatar
Re: Heads up racing
At one point, I had a set of Hoosier quick times in a p325/50r15 on a 10" wheel in the stock tubs on mine.
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 04-26-2010, 06:27 PM   #4
71chevytruckguy
71chevytruckguy's Avatar
Re: Heads up racing
I'm runnin a 28x11.5 et drag on 15x10 wheel, 4" b/s. Chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 04-27-2010, 10:58 AM   #5
team39763
Re: Heads up racing
Could you get away with running the stock tubs slightly widened with a few inches from another stock tub. Or do you think they'd notice an extra 2 inches on there? There's a guy on the squarebody site (HaulinIt), that has some completely stock looking tubs that are 1 or 2 inches wider and it looks stealthy. I'm not saying to cheat, but loosely interpret the rules in your favor.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 04-29-2010, 05:02 PM   #6
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Heads up racing
I kno wthis is off topic , but i have been wanting a class like this down here except the traction compound has to be over 200 wear rating . And no progressive or traction controls . You know just straight up street cars on straight street tires . Thought it would make for a fun class .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 04-30-2010, 04:03 PM   #7
scatesracing
Machinist
Re: Heads up racing
Yeah here they just want a dot stamp...... And the tub rule dosnt eliminate any of the newer rides that come factory with the wide meats... If they put a tire size rule in then the vipers and vetts start complaining. cant please everyone.. The first race is tomorrow http://www.truestreetshootout.com/
Old 05-01-2010, 09:58 AM   #8
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Heads up racing
Yea , i didn't think about that . Just the DOT stamp can be a very sticky tire . The tread wear of say 200 or 400 as a limiter would be the equallizer . This would be run on street xcar night so as not to tear up the track for a bracket / index event .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
