Old 02-13-2015, 01:23 AM   #1
russellrox
cab roof swap, or fix
I've got a 63 c10 swb, has rust over the windshield, just starting to get pin holes through the top roof skin, I have found a place in red deer alberta that sells the inside panel the goes around the windshield and goes back towards the headliner about 10", Lmc truck sells the outside piece that I need, should I buy a chopped top and drill all the welds and use those pieces or should I just do a whole roof swap. Who has done this before? I have a pic of the rust in my other posts from this week if your wondering how bad it is.
russellrox is offline   Reply With Quote
Old 02-13-2015, 09:52 AM   #2
LT1 Burb
LT1 Burb's Avatar
Re: cab roof swap, or fix
Change the entire roof, that way all your plug welding is under seam sealer, and it gives you the opportunity to fix any other damage on it that there may be.
LT1 Burb is offline   Reply With Quote
Old 02-13-2015, 10:39 AM   #3
Ronzo
Ronzo's Avatar
Whats the name of the place in Red Deer?
Ronzo is offline   Reply With Quote
Old 02-14-2015, 12:08 PM   #4
63sbssbbw
UCA63
63sbssbbw's Avatar
It's probably Scotts super truck in Penhold (south of RD)
Brought from there, good guys to deal with
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 02-14-2015, 11:44 PM   #5
Softpatch
Softpatch's Avatar
.What brand of seam sealer did you use.?
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 02-16-2015, 10:13 AM   #6
LT1 Burb
LT1 Burb's Avatar
Its from industrial finishes, says REM on it.
