Help me please
Here's the deal: Just bought my new truck a couple weeks ago. Drove it for quite a while with no problems. Now, i can start it up and it will stay rnning for a minute or two then die, like you just turn the key off. I checked my distributor and coil, put a new fuel pump on it, cleaned out the carb like crazy, and it still doesnt work. Yesterday i noticed that when it died, all of the lights and my radio went off with it, then turned right back on. Also, my battery died. We can charge it up with another truck and get my truck running for a few minutes, then it'l die and we have to charge the battery again. So, could this be just an alternator problem, or what? Because it has me, my dad, and all of my dad's friends stumped on what is going on.
Thanks, Collin
![]() I'm the cooler, younger version of your father. "Sally"1978 Chevy K-10 SWB/4" lift/yellow(bought her with the insurance money from charlotte) "Charlotte"1972 Chevy Cheyenne 10 LOST TO ELECTRICAL FIRE:"""""""""(((((((( ![]() "Pauline"1956 Ford F100/white primer(a tribute to my Pawpaw, Paul W. Ligon) "Purple Ice"1985 Toyota Hilux Xtracab 4x4/purple "Jill" 2004 KTM 250 EXC 2 Stroke/orange ![]() |
Re: Help me please
Sounds like your voltage regulator or possibly the alternator. You're not getting voltage to the battery (since it is not charging) or to the coil which is why it's stalling. Check the alternator first, then the regulator.
The One And Only !!!
Re: Help me please
Collin,
Set a known good fully charged battery in your truck, Start it up then check the alternator output across the battery post with a multimeter. It should put out between 13.5 to 14.8 DC volts if it's good, If much lower the alternator belt could be loose or the alternator it's self has failed.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
Re: Help me please
start with the basics. check all your battery cables and connections as well. chances are you have a bad alternator. these old trucks will run for a long while on a fully charged battery.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
