Old 11-07-2009, 08:50 PM   #1
56ClassicTruck
Rear end Question on 56..
Question or more like advice, first.... I am looking on use the rear end from my 1978 LT camaro non posi 10 bolt drive shaft, leaf and coil over shocks... would this work ok on my 56 Chevy truck.....
two......I am also looking on using the steering column non tilt with the key and blinkers........so any input would be thankful.....
I had a post I started on my 56 but don't no were it went??????
56ClassicTruck is offline   Reply With Quote
Old 11-07-2009, 10:08 PM   #2
blackdiesel
blackdiesel's Avatar
Re: Rear end Question on 56..
The spring perches will have to be moved, but the wieth is ok. I would pass on the column, but that's just me. I would us a tilt with no key.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 11-07-2009, 10:10 PM   #3
blackdiesel
Is this your thread? http://67-72chevytrucks.com/vboard/s...85#post3507885
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 11-08-2009, 12:15 AM   #4
56ClassicTruck
Originally Posted by blackdiesel View Post
Hay thanks Black, were did you fine it??? Steering column what year car or truck???????????? would work best for me??
Old 11-08-2009, 12:46 AM   #5
blackdiesel
I looked at your previous post, I like the GM van columns 60's & 70's and I think the early 80's don't have the key in them. I have used the 60's GM cars before and put a piece of tubing on them to slick them up abit. it covers up the trashy fish net looking webbing on it.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 11-08-2009, 12:12 PM   #6
pro1955
pro1955's Avatar
I believe that rear end is the same width as the stock one, you will have to move perches. I installed a 68 Camaro diff in mine 2" narrower, you can run a little deeper wheel. I have a van tilt, I didn't want the key in the column look. They are getting hard to find and of course more expensive, most will need to be rebuildt.
Truck's just for the fun of it.
pro1955 is offline   Reply With Quote
Old 11-08-2009, 02:31 PM   #7
OrrieG
OrrieG's Avatar
Look at my thread for a different perspective on the column (posts 105-120). I used an 82 Eldo that has tilt/telescope, shift, key, signals, 4 way switch, dimmer and cruise in the column. I wanted my shifter off the floor, got tired of the kids in the middle seat kicking it out of gear in the woods. I wanted key and start in one place. Getting the dimmer off the floor is one less thing to cut carpet around. Cruise is nice for a future project. I am going to cover the bottom exposed with a piece of custom metal or a leather cover to match the seats.
Old 11-11-2009, 01:45 PM   #8
Cautrell05
I did a 47 for a customer a few years ago and I used a tilt colum from an 85 chevy van. Wipers, dimmer, key shifter and shift indicator all there. Worked out real nice.
Nick
Cautrell05 is offline   Reply With Quote
