Old 11-13-2009, 04:43 AM   #1
gus
Bagged or Static Drop on my 71 K5 w/20s
here are some pics of 71 Blazer 2WD, It Has 20X10 and 20X8 Colorado Customs "Valldez" wheels with 275/35/20s and 245/35/20s.
Im ready for a suspension upgrade but I need some sugestions on this one !
Im planning to keep this set of wheels and tires But should I do front 3" JDM spindles with some 2" or 3" coils and rear is there a 7" static drop? or should I just use the 6" coils and bolt on C-Notch?
I really want a nice drop on my K5...or Should I bagged it, I already have some goodies for the air suspension like a new Blair350 compressor, selenoids, and some bags but dont have brackets, I dont have the tools to built my own brackets, so were do you suggest to buy some,
price wise is it better to bagged at this point, since I already have some parts? or drop kit?
gus is offline   Reply With Quote
Old 11-13-2009, 04:57 AM   #2
OARNGESI
OARNGESI's Avatar
Re: Bagged or Static Drop on my 71 K5 w/20s
Its just your personal preference on ride and adjustability brackets are nothing to get a member here makes plats to bolt them on the front and in the back you can replace the spring with a bag no bracket then just the air management stuff either way any pics of your trucks uncovered all the way it looks pretty nice so far
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 11-13-2009, 05:44 AM   #3
gus
sorry, I tried to post a pic but is raining hard outside, will post it tomorrow
Old 11-13-2009, 06:07 AM   #4
coolbus4us
cuts corners
coolbus4us's Avatar
I like the wheels, and say bag it. Adjustability is a good thing!
'68 Suburban named the "Cool Bus" by my kids
Follow the project here: http://67-72chevytrucks.com/vboard/s...d.php?t=331448
I love my Suburban.....a lot!
coolbus4us is offline   Reply With Quote
Old 11-13-2009, 12:39 PM   #5
gus
any one has the part # for a 3" Drop Spindle for my 71 is it DJM or Belltech?
Old 11-13-2009, 03:53 PM   #6
csa daddy
csa daddy's Avatar
i would say if ya want to get low donwn then go air bags an possible fornt drop memmber .an you can put the rear bags on the factory trailing arms an just notch the rear frame for axle travel check out ***************** they should have everything you need all brackets an all from mild drop to wild draggin the rockers off
csa daddy is offline   Reply With Quote
Old 11-13-2009, 04:12 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
If you have the means, and it sounds like you already have some of the components... bag that thing!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-13-2009, 04:38 PM   #8
chevy truck crazy
chevy truck crazy's Avatar
Bag it
chevy truck crazy is offline   Reply With Quote
Old 11-13-2009, 06:33 PM   #9
gus
..........k will bag it, there's no Votes for static drop !
Yes, since I have some stuff already collecting dust for a year, I think it will be much better to bag it, What I need is a nice set of drop spindles someone here on the forum recomended me a 3" spindle(?), I know there's 2.5 spindle from CPP or ECE, crossmember is a good Idea, But I also have 3 kids to feed, so I'd like to get just the brackets and re-placed my ball joints and bushings.
I see alot of you guys are from TX AZ or East Coast, anyone in O.C.714 that can recomended me to an airbag shop?
Here's the uncovered pics.!
soon will post some pics. of the parts that I already have !
Old 11-13-2009, 07:39 PM   #10
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Glad to finally see the Blazer out from under the covers...
Static drops work well too, but since you're trying to keep within a budget, that's why I recommended the bagged suspension. However, since you will be planning on hauling the family in the blazer, the bagged rear will definitely help with ride quality and if you're bagging the rear then why not do the front while you're at it.
-Nate
Old 11-13-2009, 08:22 PM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
Either way you will need other parts besides just bags and drop spindles.
1) Good quality drop shocks.
2) Rear shock relocators
3) Some type of adjustable track bar. (Super Track Bar from ECE is the best in my opinion)
4) a bolt in c-notch
5) a 2 inch lowering block for the rear will also help with the final ride height and for getting the rear axle tube up into the notch when air'd out.
I suggest Early Classic Enterprises (ECE) for all your parts>
Keith
Convert to disc brakes.
Old 11-14-2009, 03:38 AM   #12
gus
Here's some of my parts !
Lolife:
2" blocks? where do you install the blocks if it would have airbag?
sorry for my ignorance, I'm not good at this, but Im trying to learn from you guys !
Old 11-14-2009, 02:00 PM   #13
lolife99
lolife99's Avatar
Lolife:
Between the trailing arm and the rearend housing.
Keith
Old 11-15-2009, 03:26 AM   #14
gus
does ECE has the 2" blocks?
