Old 11-23-2009, 12:15 AM   #1
muckyp
muckyp's Avatar
What front end????
How can I identify what year model front end I have? I bought an unfinished project and can't remember what year model he said the front end was.
muckyp is offline   Reply With Quote
Old 11-23-2009, 12:30 AM   #2
Mowdigger
Mowdigger's Avatar
Re: What front end????
Post a picture of the front end. Grills are different on numerus years, hoods are different. Post a pic and let everyone here give you an idea.
Mowdigger is offline   Reply With Quote
Old 11-23-2009, 11:51 AM   #3
muckyp
muckyp's Avatar
Sorry, by front end I meant spindles, rotors, brakes etc.
Old 11-23-2009, 12:02 PM   #4
68lwb292
Ex-Minitrucker
68lwb292's Avatar
Well if its 5 lug its the later years 71 & 72 I think. I know the older ones are 6 lug with drum brakes
68lwb292 is offline   Reply With Quote
Old 11-23-2009, 12:19 PM   #5
westofb
I really hate wet sanding!
westofb's Avatar
Or 73-87, if 5 lug, those parts with a lttle effort fit also. I would say you are going to have to find a known vintage front end to compare it to, the 71-72 are the same, as are the 73-87 with the exception that some have 1" rotors and some have 1.25" rotors (thickness of rotors that is, I believe in those years the spindles/ rotors/ and brakes are not interchangable). I don't know the thickness of 71-72 rotors off top of my head.
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
westofb is offline   Reply With Quote
Old 11-23-2009, 04:24 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
71-72 had disc brakes and steel screw in control arm bushings.
73-87 had disc brakes and rubber control arm bushings.
73-87 upper control arms have a 3/8 hole in the front of them for the brake line mounting tab to screw in to which 71-72 do not.
71-72 brake lines run across the crossmember and mount to tabs on each side right in front of the crossmember.
73-87 brake lines did not run across the crossmember at all. They ran down the inside of the frame rails.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-24-2009, 02:28 PM   #7
muckyp
muckyp's Avatar
Thanks. That's what I was looking for. I have been reading on here for a long time and your knowledge of this stuff never ceases to amaze me.
Old 11-25-2009, 06:50 AM   #8
bestchevyfan
Well said, tx f.f.
bestchevyfan is offline   Reply With Quote
Old 11-25-2009, 07:11 AM   #9
kev2809
low n' slo
kev2809's Avatar
that single post should be a sticky...maybe with a pic of each. nice info
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
