Old 11-24-2009, 11:21 PM   #1
bradf74
Just replaced passenger front flexible brake hose and...
Need a little advice (79 2wd disc brakes). The line busted and replaced without an issue. Do I need to bleed the entire system or just the front brakes?
Brad
bradf74 is offline   Reply With Quote
Old 11-24-2009, 11:26 PM   #2
bitchin85
bitchin85's Avatar
Re: Just replaced passenger front flexible brake hose and...
you should only have to do the fronts.. but if i were you id just go ahead and bleed em all the way around to make sure u got all the air out
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 11-24-2009, 11:29 PM   #3
nlped
nlped's Avatar
You can typically just bleed the affected "end" of the truck if it has a 2 reservoir style master cylinder which your year truck should have.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
