Old 09-04-2010, 07:54 PM   #1
DetroitIron
DetroitIron's Avatar
Replacing leaky valve cover gaskets on my 85 K20
Any suggestions for type of valve cover gasket to use or advice on whether any special prep to the gasket or cover is needed? Thanks for any suggestions. btw- I was suprised how many vacumn lines, left over smog hoses,etc. needed to be moved to pull the cover...just took my time and kept telling myself how much $$ I'm saving by doing it myself.
_______________________________________________
1985 Chevy Scottsdale K20 350 with 700R4 running 3.42 gearing aka "The Honey Badger"
1993 Silverado C3500 Ext. Cab Dually 6.5 turbo diesel
DetroitIron is offline   Reply With Quote
Old 09-04-2010, 08:52 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Replacing leaky valve cover gaskets on my 85 K20
Fel-Pro gaskets with a light film of THIS THIS applied with your finger will help seal them. Make sure the cover screws weren't over tightened and cone shaped the hole, If so lightly tap them back down flat with a small hammer.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 09-04-2010, 09:13 PM   #3
DetroitIron
Thanks very much....Appreciate the info.
Old 09-04-2010, 09:27 PM   #4
mooseknuckles
mooseknuckles's Avatar
clean the head and valve cover real good, use fell-pro gaskets and glue the gaskets to the valve cover only with 3m weatherstip adhesive. do not over-tighten.
mooseknuckles is offline   Reply With Quote
Old 09-04-2010, 11:28 PM   #5
truckerboy
Use Fel-pro or Mr. Gasket and clean the rocker cover and head good. make sure to either get a shop manual or the torque settings from the parts house that you get the gasket from.
One thing you may run into is to get rubber or cork. I usually choose cork as in my experiance it seals better than the rubber. Also, cork has better thermal expansion than rubber does.
79 K20,400 SBC, TBI, 4 speed w/ super low, 4.88's.
89 K2500. 350 TBI, mild cam, longtube hooker headers, glasspack true duals, TH700R4 with shift kit, Corp. 14 10.25'' full float, with 4.11:1 gears, standard ifs cranked to 2 inch lift. RS5000 shocks.
96 f350, Powerstroke, ZF6, DRW, 4x4.
.Real trucks have 3 peddles. Real drivers float gears!!
truckerboy is offline   Reply With Quote
Old 09-05-2010, 11:01 AM   #6
54Caddy
GM Addicted
54Caddy's Avatar
i am running these ones here. As it says no need for silicon just make the head and the valve cover base clean so there is no debris and they work great not one leak yet. I tend to lean towards "You Get What You Pay For"
Valve Cover Gaskets
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 09-07-2010, 10:56 AM   #7
DetroitIron
Thanks all....Felpro rocks...so nice to open hood and not smell oil burning on manifolds/see smoke. Now if I can just solve my small oil leak somewhere on the rear side of the engine (passenger side).
Old 09-07-2010, 12:17 PM   #8
Adams74Chevy
Adams74Chevy's Avatar
...Or sitting at a stop light or stop sign and the guy next to you looks nervous because of the smoke plume coming out from under the hood.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic
1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208
1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his.
1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out.
2016 Nissan Altima grocery getter/commuter
Adams74Chevy is offline   Reply With Quote
