Old 11-30-2009, 05:11 PM   #1
Tim240Z
Tim240Z's Avatar
Replaced rear bushings but still 'unstable'
On my C20 Burb, I replaced the track bar and control arm bushings in the rear with urethane ones, but at speed the rear of the truck still seems very 'loose'...
Hard to put my finger on it, but it feels like the rear end is floating around back there.....never felt like this with my 71 truck....maybe just the way these burbs are? Very unsettling feeling especially on the freeway, going around a bend with a rough, or washboard type road surface....takes every bit of concentration to keep it in a lane.
I have replaced the steering box and the pitman arm in the front and all else appears tight and good....
Any suggestions? All shocks appear and feel to be good (paint still clean and the rears had lots of push to them when I did the rear bushings - unbolted the bottom mount - they were obviously done fairly recently by the PO)
1972 Suburban C20
454/TH700R4, eaton-corporate 4.10 (looking for 3.7)
Sold: 71 Cheyenne 20
Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005)
Tim240Z is offline   Reply With Quote
Old 11-30-2009, 08:52 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Replaced rear bushings but still 'unstable'
Are you running bags or springs? How much drop? Do you have new shocks? Shock relocators?
Hart_Rod is offline   Reply With Quote
Old 11-30-2009, 09:24 PM   #3
Tim240Z
Tim240Z's Avatar
I mentioned the shock condition above...as for the rest:
Coils, no drop or relocation...all is stock. I'm sure that the springs are getting weak as they are approaching 40 years old, but I can't see that causing the problem?
1972 Suburban C20
Old 11-30-2009, 09:32 PM   #4
Hart_Rod
Hart_Rod's Avatar
I missed that about the shocks. What type of tires are you running?
Old 11-30-2009, 09:34 PM   #5
Tim240Z
Tim240Z's Avatar
245/70-17 BFG Rugged Trail, load range E, (off of a new Ram 2500).
1972 Suburban C20
Old 11-30-2009, 09:39 PM   #6
Hart_Rod
Hart_Rod's Avatar
I think some new springs would help, but I don't think that's the entire problem. How much air are you running in your tires? I had a similar problem when I let the pressure in my rear tires get low.
Old 11-30-2009, 09:40 PM   #7
Tim240Z
Tim240Z's Avatar
50psi
1972 Suburban C20
Old 11-30-2009, 09:42 PM   #8
Hart_Rod
Hart_Rod's Avatar
50psi
Interesting. That seems high, but I'm not sure what is a normal pressure for those tires. I would suggest trying 40 psi and see what that does.
Old 11-30-2009, 10:19 PM   #9
Tim240Z
Tim240Z's Avatar
I figured that since the tires had a very stiff sidewall, the high pressure could only help (max press. is 80psi iirc).
I'll try drop them, but my gut feeling is that it will just get more mushy?
1972 Suburban C20
Old 11-30-2009, 10:41 PM   #10
Hart_Rod
Hart_Rod's Avatar
You're probably right, but it's free to lower the pressure, . The only other thing it could be is the springs. Do you plan on upgrading them any time soon?
Old 11-30-2009, 11:10 PM   #11
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Are you sure it's in the rear? Maybe it's the steering that's loose and you're just feeling the rear of the truck amplify the problem? Also I know in my burb it starts to feel kinda top heavy when you are pushing through the twisties just a little to fast.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 11-30-2009, 11:14 PM   #12
2tons of fun
check your lower shock bracket, i tore mine apart and its was a stock truck that i babied.
they are a crappy single shear design and have a tendency to tear. weld a heavy spacer to the braket and it will bullit proof it.
2tons of fun is offline   Reply With Quote
Old 11-30-2009, 11:22 PM   #13
Tim240Z
Tim240Z's Avatar
Like I said above, I replaced the box and pitman arm....everything else looks ok, except the bushings for the sway bar (only have the front one, no rear sway yet), which are mushy from past oil leaks.
I guess I could just replace the ball joints since they are likely original. I was hoping that I would feel a significant difference when I changed the rear bushings as the originals were shot, but I was very disappointed.
Everything looked OK when I was under there....where does it break?
Thanks guys!
1972 Suburban C20
Old 11-30-2009, 11:36 PM   #14
jrods70
jrods70's Avatar
My fathers 71 suburban had a problem like this and it turned out to be loose u bolts on the axle years or rust ate away at the mount and bolt. Cleaned the mount up and put new u bolts fixed it.
jrods70 is offline   Reply With Quote
Old 11-30-2009, 11:53 PM   #15
Tim240Z
Tim240Z's Avatar
When I did the bushings, I loosened the U-bolts, then re-tightened again....they must have been replaced at some point as they are still quite nice....I guess they could have loosened, I will check tomorrow.....
TIm
1972 Suburban C20
Old 12-01-2009, 05:13 AM   #16
2tons of fun
the break at the hole for the shock bolt.
